Old February 24, 2010, 07:03 AM
jcmaz's Avatar
Default Fan Controller Recommendations?
Hey HWC,
All the fans in my Antec 300 is making my whole family sick. I think its due to the displacement of air. So i'm in the market for a fan controller.
I'm hoping that i'll be as cheap as possible, but mounted in a 5.25" drive slot.
Are these ones any good, if not, please recommend me a cheap fan controller.
Newegg.ca - Thermaltake XCONTROLLER 5.25" Drive Bay Kits - Fan Controller w/ LED Light - Controller Panels
Newegg.ca - NZXT Sentry-2 5.25" Touch Screen fan controller - Controller Panels
http://ncix.com/products/index.php?s...cture=Lamptron
http://ncix.com/products/index.php?s...acture=Sunbeam
-Plato
Old February 24, 2010, 02:14 PM
Beastylemon's Avatar
Definatly the Third one. The "Lamptron FAN-ATIC 5.25IN Bay 5 Channel Fan Controller Blue LED Military Switch 60W Per Channel "
It Blends in with the case mostly and its not touch. i am against touch, because it leaves marks from your hand and stuff
Old February 24, 2010, 04:25 PM
jcmaz's Avatar
I dunno, the Lamptron Hummer is dirt cheap at Best direct for $20...
-Plato
Old February 25, 2010, 08:19 AM
sunbeam, yank the stupid blinding leds out. i ahd it in my haf cases with a couple fans hoohed to each channel with no issues
Old February 25, 2010, 08:28 AM
AmuseMe's Avatar
I'm not a nob "fan" (pun intended) but the Sunbeam Rheobus Extreme is definitly a good choice. The Lamptron ones have a reputation to make a squeeling sound, but that is only some of them @ 60W a channel though, that is some serious power. The Rehobus Extreme does 30W per-channel.
DEAD CA$H
Old February 25, 2010, 08:31 AM
BigDogg's Avatar
Are those Lamptron ones not just fan switches and not fan controllers? I have owned the Sunbeam Rheobus Extreme (my fav so far), the Lamptron FC3 (RMA due to High Pitched Squeal, was told by Lamptron this is normal), and the NZXT LCD screen one which works well but feels kind of cheap.
I am however going to get the Lamptron FC5 as my next controller to try it out. I would love to get another Sunbeam but NCIX doesn't have the Black version in stock for months now.
CPU fan recommendations dante1 Air Cooling 18 January 18, 2010 08:15 PM
Which Fan Controller? Signal2Noise Air Cooling 24 August 24, 2009 11:34 PM
zalmaan 6 fan, fan controller quikgp Peripherals 4 May 29, 2009 09:32 PM
GTX480 Fan Recommendations Infiniti Water Cooling 26 July 17, 2008 10:57 AM
Fan Controller Computergeek Air Cooling 5 July 9, 2008 06:16 PM
