<~----> Thermal tape and other solutions... - Hardware Canucks
Old February 20, 2010, 02:45 PM
Post Thermal tape and other solutions...
Hi there!
I need some thermal tape for a mosfet block on a motherboard.
I would like to know what kind of thermal tape do you use?
there is this one:
Thermal Tape 3.5CM X3.5CM ( One Piece ) - DirectCanada
But we don't have much details on it...
or the Sekisui 5760 Dbl sided thermal tape that you could find on ebay.
And do you have a way to fix (not permanently) memory and mosfet heatsink?
or I should stick with the thermal tape?
Old February 20, 2010, 03:12 PM
CroSsFiRe2009's Avatar
That stuff should be 3M tape.
Old February 20, 2010, 04:54 PM
stoanee's Avatar
Would you be interested in glue?
http://ncix.com/products/?sku=10716&...rctic%20Silver
heatware
Old February 20, 2010, 05:02 PM
MarkOne's Avatar
stoanee ... 2 things .. first of all this stuf will not permit removal of the thing you glue with it , it's epoxy secong..if it's not a problem, better use the one without silver, it will avoid problem, it's the one I use for mount my memory heatsink in video card, but you can remove them later to put back the regular cooler
http://ncix.com/products/?sku=666624...rctic%20Silver
Old February 20, 2010, 06:00 PM
Jackquelegs's Avatar
Shoot me a PM, I have 50M of the Sekisui double sided tape
Iapetos
Zephyranthes
Old February 20, 2010, 06:31 PM
stoanee's Avatar
So far have been able to remove anything I have glued with it.
heatware
Old February 20, 2010, 10:55 PM
I'd ask if you left out a c in the 50M for centimetres.....but I know better
Old February 21, 2010, 06:33 AM
Default re
The thing is that I really want to be able to remove it after...
And does the Sekisui is thin or tick?
Thermal tape for GPU mem Eldonko Video Cards 54 May 14, 2010 01:54 PM
Voltage regulator block (Thermal tape or thermal counpound?) Mavvens Water Cooling 5 August 8, 2009 06:56 PM
[WTB] Thermal Tape punk_zappa Buy/Sell & Trade 0 June 28, 2009 02:15 AM
Thermal pads or tape for GTX on water. Sniper Video Cards 3 December 4, 2008 10:06 AM
Akasa AK-TT12-80 Thermal Adhesive Tape Hardware Canucks Reviews & Articles from the Web 2 May 7, 2008 02:22 PM
