Old February 15, 2010, 05:02 PM
Default Help choosing Heatsink Cooler
Hey folks my mind is mush from reading reviews on Coolers. I figured why not ask the audience. I want to push my E8400 a bit higher I've read the e8400 can be pushed to 4.0 GHz I don't necessarily need to go that high wondering what type of cooler I should purchase for this.
My setup is as follows : E8400 at 3.0 GHz l Evga 750i SLI FTW l WD 7200 640 GB Black l 4 GB G-Skill DDR2-1066 l Evga 260 GTX and BFG 260 GTX 216's SLI l Corsair TX750 W l CM 690 case
Thanks
Old February 15, 2010, 05:07 PM
MarkOne's Avatar
you can push the e8400 at 4ghz with any good cooler. the Cm 212+ is more than enough for it
Old February 15, 2010, 05:38 PM
The Cm 212+ was one i looked at in the very beginning then i started reading to much on newer coolers and which is suppose to be the best so on so forth but if the the Cm 212+ can do the job why spend extra
Old February 15, 2010, 05:43 PM
MarkOne's Avatar
if the 212+ can do the job on I7 CPU , a e8400 produce way less heat, you can add a second fan to it, to improove the performance too
Old February 15, 2010, 05:46 PM
gingerbee's Avatar
I think you mean the i7 produces more heat then an e8400. well everyone i every had did not even come close to my i7 chip
back wards writing happens to me all the time
Old February 15, 2010, 05:48 PM
MarkOne's Avatar
corrected
Old February 15, 2010, 05:49 PM
another CM fan or maybe a Yate Loon --- and it would be push pull right
Old February 15, 2010, 05:50 PM
gingerbee's Avatar
bingo and should be good enough For a e8400
Old February 15, 2010, 05:52 PM
MarkOne's Avatar
put the same Cm fan on the other side . do not mix different fan.
Old February 15, 2010, 05:57 PM
Sounds good to me 2 fans and cm 212 + to my order list
thanks folks
Need help choosing from some I7 Mobo's quikgp CPU's and Motherboards 3 May 28, 2009 04:51 PM
choosing some DDR2 firn RAM 25 April 6, 2009 07:39 AM
Help choosing a 24 LCD jin15 Display Units 8 August 17, 2008 10:28 PM
Need help choosing a motherboard SmogTown New Builds 5 August 17, 2008 09:15 PM
Need help choosing! Kassela CPU's and Motherboards 5 December 20, 2007 02:56 PM
