Old February 7, 2010, 03:03 PM
FreeKnight's Avatar
Default CPU Fan Splitter Plug
Hey Everyone,
I have a Mugen II CPU cooler that I want to pop a second fan onto. Does anyone make a plug adapter so I can run two fans into the CPU fan socket? I know I have the option of a Fan controller, but I'd just as soon run the fan control off the MB especially since I don't have any other fans that need to be plugged into the controller.
Thanks for any help you can provide
Old February 7, 2010, 03:20 PM
FreeKnight's Avatar
Nevermind, a little more searching and I found out they're called y adapters/splitters.
Old February 7, 2010, 03:56 PM
rjbarker's Avatar
nGear...about $3 at NCIX, its what I use for my Push / Pull 120mm Fan config on my TRUE.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old February 7, 2010, 09:59 PM
I got this one from NCIX. You can PM it down to just 88 cents.
Old February 7, 2010, 11:23 PM
Raserei408's Avatar
Just make sure you get a 4-pin PWM one.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old February 8, 2010, 09:53 AM
rjbarker's Avatar
^^^ Nice but not necessary.
MARK 11: 32.530
Fan Controller : Can you use a Splitter? BobbyLou Air Cooling 5 December 8, 2009 11:57 AM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
Is there a way to get yate loom to connect to cpu fan plug? Shadowmeph Air Cooling 3 March 30, 2008 05:37 PM
3 Pin to 4 Pin Fan Plug Adaptor? Thund3rball Video Cards 6 March 25, 2008 01:46 PM
xfx motherboard, vreg fan plug?? Ukonjack Troubleshooting 1 December 3, 2007 09:27 PM
