Old February 7, 2010, 09:16 AM
Toyoracer's Avatar
Default PWM by motherboard or fan controller?
I am looking for pro's and con's on which fan control is more reliable. Will have 3 sets of fans cpu,graphic cards and case. So the temp at each will determine rpm. Each fan set will have an I/O fan connected to it. I am looking at Gigabyte FXT board, so connect to that board or to a fan controller looking at CFA-635-scab
https://www.crystalfontz.com/product/SCAB.html
This will be a positive pressure case and be using oc profiles depending on what I am doing. Still in design stage so open to suggestions based on pro/con.
Old February 7, 2010, 07:48 PM
Toyoracer's Avatar
How about hooking up to motherboard or fan controller which is better?
Zalman Releases Manual Fan Controller for PWM Soultribunal Press Releases & Tech News 0 November 10, 2009 11:12 AM
zalmaan 6 fan, fan controller quikgp Peripherals 4 May 29, 2009 09:32 PM
Which fan controller? donkon Air Cooling 7 May 16, 2009 05:22 AM
fan controller help kyle_L Air Cooling 4 March 5, 2009 11:51 PM
can PWM fans be used without PWM controllers? solaris10 Air Cooling 0 February 4, 2008 10:29 AM
