From the review:
However, unlike the Extreme version which uses aluminum as the transfer medium, the Flex has a solid copper base. While copper is not as efficient a transfer medium as aluminum, it can soak up more heat and we believe it will result in a net gain.
This is incorrect. Copper has higher thermal conductivity than aluminum and transfers heat more quickly.
Also, I suspect the CNPS10X Extreme uses a copper base as well, though it is nickel-plated. Most high-end coolers with nickel-plated bases do use copper.
