Old January 27, 2010, 09:51 PM
N.V.M.'s Avatar
Default HSF help
i'm looking for a replacement for my Phenom II(AM3) cooler, but there's limitations/restrictions. my memory sticks, actually the shields
on them, are very tall.(50 mm/2" ) also total height cannot be more than 100 mm/4" . no, i am not getting shorter sticks or losing the shields. last, quiet. any suggestions?
in this picture, the first stick is 6 mm/1/4" away from the stock cooler, just to give you the idea.
i was looking at something like this:
http://ncix.com/products/index.php?s...facture=Noctua
but its 114 mm with the fan, so slightly too tall, but honestly i could sneak it in there if i had to,but not the most ideal. more importantly though, i can't tell if it'll clear my sticks.
Old January 27, 2010, 10:21 PM
Corsair H50? It'll fit, it'll be relatively quiet, but it is a bit expensive. There's the Zalman CNPS8700. (being defeated by this editor thing)
Old January 27, 2010, 11:15 PM
N.V.M.'s Avatar
nice. i'll investigate that more. not sure about the Zalman though. looks low?
Old January 28, 2010, 12:38 AM
sswilson's Avatar
Are you running 4 sticks of memory? Have you checked to see if there was any real penalty to using the second bank of mem slots? Most manufacturer's "recommend" using the slots closest to the cpu, but in real world apps there's often not much (if any) difference to performance.
Old January 28, 2010, 12:46 AM
aCid888*'s Avatar
I used the other banks on my board for a while and saw no performance hit....I'd just move the sticks.
Hers (pInky):
945ES @ 3.92GHz (1.5v) - Lapped Fuzion v1
MCP-355/XSPC Top + Black Ice Extreme 360
Asus M3A79-T Deluxe 790FX (MX-2 NB + SB)
2x2GB G.Skill Pi Black @ 900MHz 444-12
PNY "XLR8" 9800GX2 @ 704/2202/1760
Seagate 500GB + XP SP3
22" Acer P223w @ 1680x1050
Modded Lian Li PC-60F
SB Audigy 2 w/ Heatsink
Old January 28, 2010, 07:33 AM
N.V.M.'s Avatar
could do that but i'd be screwed if i wanted to add more memory later on.
Old January 28, 2010, 07:38 AM
Soultribunal's Avatar
Thermaltake Typhoon Pro or Typhoon V14. They will sit higher than the those XMS sticks for sure and even provide some cooling given that it is a downdraft cooler.
Regards,
ST
www.realhardwarereviews.com
Sub $20 HSF Opinions jcmaz Air Cooling 12 November 9, 2009 08:20 AM
Best HSF for a P2 955? ADay2Long Air Cooling 7 August 4, 2009 01:06 PM
Best hsf for e8400 !? CraigHf Air Cooling 22 December 18, 2008 02:03 PM
which is the btter hsf? v0maru Water Cooling 10 January 17, 2008 06:16 PM
Scythe HSF any good ? Jim Water Cooling 13 March 30, 2007 06:58 AM
