Old January 17, 2010, 12:23 PM
dante1's Avatar
Default 80mm case fans
I need to replace my case fans with some that are more quiet. Does anyone have recommendations for good quiet 80mm case fans? I am looking for blue fans.
I found these Buy SilenX Corporation [IXP-54-14B] Silenx iXtrema Pro 80MM Blue LED Quiet Fan 1700RPM 32CFM 14DBA Fluid Dynamic Bearings 3/4PIN but just wondering what you guys prefer.
Thanks,
Dante1
Old January 17, 2010, 12:54 PM
Sushi Warrior's Avatar
Best fans:
http://ncix.com/products/?sku=38060&...facture=Scythe
http://ncix.com/products/index.php?s...lutions%20Ltd.
http://ncix.com/products/index.php?s...facture=Noctua (overpriced, but if you want to buy into hype...)
Best blue fans
http://ncix.com/products/index.php?s...acture=ENERMAX
http://ncix.com/products/index.php?s...ufacture=Antec
I vote for the Gelids. Cheap, quiet, and white/black looks REALLY good IMO.
Old January 17, 2010, 02:02 PM
Raserei408's Avatar
If you really want something quieter, drill some holes for 120mm case fans. They move a lot more air and are A LOT quieter.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old January 17, 2010, 04:32 PM
80mm panaflo. Undervolt if "full power" is too loud.. I can't hear the damned things at 12v, but if you've got that acute of hearing, 7v or 5v = pretty much dead silent.
This model:
NCIX.com - Buy NMB-MAT (Panaflo) 80MM Hydro Wave Bearing Fan 1900RPM 24CFM 21DBA 3PIN W/SENSOR 80X80X25MM RoHS - FBA08A12L1BX In Canada.
Case fans to MB or PSU? ontariodude Guides & How-to's 14 September 28, 2009 01:31 PM
[WTB] Case fans (only for Soultribunal) Realityshift Buy/Sell & Trade 2 April 20, 2009 10:27 AM
Connect case fans to the motherboard? Dogger1 Air Cooling 8 February 28, 2009 01:32 AM
Case Fans? chouchou Air Cooling 3 October 24, 2008 06:49 PM
suggestions for case fans..... rob123 Air Cooling 18 August 13, 2008 08:19 PM
