Originally Posted by Soultribunal It actually is idling without the PowerSaving mode. Its not loaded up 100% but its not in its most power efficent mode either.
ST |
and it's why when some one post idle temp , they are temp take in windows with EIST ( thanks to CM) lowering the clock , so the temp are lower than in the BIOS.
We will all arrive at the same place finally.
For the 300, put 2 x 120 on front of that case, you HD will greatly appreciate it too. if the one at the back is not blue, order 3 with blue led. I like the blue color of my 1200 one.
