Originally Posted by CMetaphor I think markone is a little confused, but what I think he means is the EIST is not active when the PC is in the BIOS (pre-OS). Aka, your system not using speedstep to reduce its speed and temperature unless it's idling in Windows. You'll probably get lower Idle temperatures in Windows because of this. . |
Me confuse
( all the time
that's it..... it's what I means since the start.. the OP compare the temp with data where the EIST is active. Only after Installing Windows he will be able to compare with the results of the other one.
all true I agree than some more ventilation is need .
I have never be good to learn all those technical therms. to much of them, changing every minute
By the way CM.... how come you seams so literate with Intel technology......
I know stay close to your friend and closer to you enemies
