Originally Posted by CMetaphor been pulling and swapping cpus too often for a bolt-through setup... and as a result im using the stock Amd cooler right now. Why? Need to have a fast and easy system to allow for tim/cpu changes. So, could i get a few suggestions for a good option that uses the AMD clips system or something just as easy to use (no access to the back of the motherboard). Thanks in advance guys...
PS: E/W orientation would be stellar as well. |
vendetta 2 is easy to remove, but is n/s
