  #21 (permalink)
Old January 5, 2010, 12:49 PM
martin_metal_88's Avatar
Maybe you should get a more spacy and airflowly better fan. Really great computer indeed how do the cooler is in this direction? still good or you find it not a great upgrade from previous?
  #22 (permalink)
Old January 5, 2010, 06:03 PM
AKG, i hv only one word for this review..."THOROUGH". I think you may possibly hv the most "painstakingly careful and accurate" (from google Definitions) review on Noctua NH-D14 on the entire internet!
That said, I kind of belong to group that still can't believe that it lost to "Titan Fenrir" on so many occasions. I can accept that megahalems wins it by a bit, give and take, but Titan!? It cost about ~$30 less than NH-D14. (Its smaller, comes with a fan, cheaper and does its job better).
So i'm going ask a question which i already know the answer to. When you conducted the test using Scythe G and NF-P12 on the NH-D14, was Titan Fenrir using the these fans as well or its 2150 rpm stock fan? (my last attempt to look for any discrepancy).
  #23 (permalink)
Old January 5, 2010, 06:15 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Thank you JohnJohn.
Yes all coolers were run with the same fan in a given test. I was happily surprised at how well it did in the single fan results (as past dual tower designs down right stank). It really is THAT good a cooler and I was THAT impressed with it.
Honestly, the Titan Fenrir is a kick ass cooler. So too is the D14. Both are best in class coolers. Both are designed for different niches. At lower heat levels HDT coolers are the king of the hill (but in the next air cooler review...they may have some stiff competition from a solid based cooler!). At max oc / heat loads the D14 is king of the hill. BUT the D14 really needs two fans to kick ass. It was obviously designed from the ground up to run two or three fans and not one. I would never recommend running the D14 with only 1 fan (even though it can and do decently while doing it), but considering the fact that it ships with two this is not a big deal ;)
  #24 (permalink)
Old January 5, 2010, 06:36 PM
MarkOne's Avatar
well, that's the space I have , the small 80 mm fan is for my VRM rad , I will just have to remove 2 screw to switch the cooler, as they use the same base , I use the 120 mm fan instead of the 140, because it was not clearing my small rad , I will use the other VRM rad for the N14
  #25 (permalink)
Old January 5, 2010, 07:07 PM
This is one fine review - probably the best cooler review of any kind I have ever read anywhere. The testing methodology plus the different fan configs..even configs that admittedly won't be used in any normal rig really sheds some light into what makes the cooler tick - single fan, dual p14s, dual P12s...wow just wow. And I really like the sampling from other coolers. Most cooler reviews might test against 1 or 2 other coolers if lucky.
Thanks. A really enjoyable read.
  #26 (permalink)
Old January 5, 2010, 08:26 PM
Lamb's Avatar
Finally a good review on the Venomous X?
  #27 (permalink)
Old January 6, 2010, 01:51 PM
Can we have a hint on when this review will show up maybe next week? And... is it me or the air cooler market have grown fast in 2K9? Many new company many new design and better and better cooler all months. Maybe more in 2K10
  #28 (permalink)
Old January 6, 2010, 02:04 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
The review will be up next week or the week after.
  #29 (permalink)
Old January 6, 2010, 02:37 PM
MarkOne's Avatar
Sky....Let them wait........
  #30 (permalink)
Old January 6, 2010, 02:55 PM
Mark how can you wait:P you know that if he perform well you are going to order it so:P
Noctua U9 CPU Cooler Review comment thread AkG Air Cooling 16 October 8, 2008 10:16 PM
Noctua NH-C12P CPU Cooler Review comment thread AkG Air Cooling 6 July 28, 2008 11:29 PM
Noctua NH-U12P CPU Cooler Review comment thread AkG Air Cooling 8 May 27, 2008 04:34 PM
Comment Thread for Noctua NC-U6 Chipset Cooler Review Supergrover Water Cooling 11 July 1, 2007 02:47 PM
