Old January 4, 2010, 05:51 PM
Lamb's Avatar
Default Should I change my cooler?
Hey guys,
today i received my new 920 d0 and managed to push it to 4.0ghz with these settings and all seems stable now
BCLK [201]
Clock Ratio [20x]
CPU Uncore [16x]
PCIE [100Mhz]
CPU Vcore [1.300V]
CPU VTT [+100mV]
CPU PLL [Auto] (1.8V)
QPI Vcore [1.48V]
DIMM Voltage [1.65V]
IOH [1.4V]
IOH/ICH [1.65V]
ICH Vcore [1.25V]
Mem. Freq. [2:8] - 8-8-8-24-74-1T
But one thing is worrying me, the temps, @ 100% they seem to average around 80 to 85, which I think is a little high...!!
So come to the question; Should I upgrade my Corsair H50 to a Thermalright Venomous X (would I see a noticeable difference? I'd keep the same fans) or is WC the only way out for better temps ?
Old January 4, 2010, 06:34 PM
stoanee's Avatar
I was running about 70C or so with a Megahalem in push/pull so I went to water. Now at 60 ish. (prime 95 and 4 ghz)
heatware
Old January 4, 2010, 06:39 PM
Lamb's Avatar
I don't care being in the 70's, 80+ is just too much, now my CPU crashed twice because the temps would hit near 90 (or be it unstable OC, the temp doesn't help)
Venomous X it is!
TR-VX seems to destroy both Megahalem and Cu-TRUE which were supposed to be the top dogs with the NH-D14, which all performed better than the Corsair H50...I'll stay in air cooling for now, looked at the prices for a 'top-quality' WC loop and it's a little out of my budget for now! I'd want Heatkiller + MCP655 + Feser Triple Rad + 3 Gentle Typhoons....around 450$ for great performance because I don't want to cheap out and go with a Swiftech Rad and a lesser block (if I go into WC, every C will count ) so I'll stay with the top air solutions!
Old January 6, 2010, 08:56 PM
The TR-VX won't be amazingly better than the TRUE and Megahalems, maybe 2-3c.
Watercoolings another story, it's only good if you have time to maintain it.
Old January 6, 2010, 09:14 PM
Lamb's Avatar
2-3C less on a 100% load PC 24/7 can make quite a difference , and it shall be more than 2-3C difference with my current H50!
Old January 6, 2010, 11:30 PM
the megahalems will destroy the Thermalright Venomous X
get better fans on the h50
my megahalems handles my 920@ 4.5 nicely
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old January 6, 2010, 11:37 PM
Hey
I would reccomend the venomous X because it does better than the H50, only 1 rad is not going to coole you system.. besides water cooling kits have problems, the pump dies quickly at high temperatures.
If I were you I would go for the venomous X, you can also lap it.
Old January 6, 2010, 11:55 PM
Originally Posted by PCPAIN View Post
Hey
venomous X is a waste of $$ 26$ coolmaster 212 will slap it silly
mehahalems owns em both
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old January 7, 2010, 07:49 AM
gingerbee's Avatar
what ? even if your silly and never clean out your loop you'll stlll get way better then any air cooler ( it's water )
Old January 7, 2010, 08:02 AM
MarkOne's Avatar
Open your windows to reduce the room temp. pretty cool outside on this time
Name change? Evylldemon Off Topic 2 November 22, 2009 04:32 PM
I think i need a case change? dinmaster Cases 23 September 18, 2009 07:49 AM
OCZ's Cryo-Z phase change CPU cooler Hardware Canucks Air Cooling 0 May 8, 2008 10:23 AM
Career Change Prof. Dr. Silver Off Topic 20 January 19, 2008 11:21 AM
No boot after bios change mattydies Troubleshooting 4 October 21, 2007 07:21 PM
