Old January 3, 2010, 02:08 PM
dante1's Avatar
Default CPU fan recommendations
I am putting together a new rig and was wondering what CPU heatsink and fan I should go with.
Here is my setup
CPU: i7 920
Mainboard: either a Gigabyte Gigabyte EX58-UD5 or an Asus P6T
Video Card: Radeon 5770
Memory: G.SKILL F3-10666CL9D-4GBNQ PC3-10666 4GB 2X2GB 30167
I am looking to spend no more then $50.00
Thanks
Dante1
Old January 3, 2010, 02:24 PM
stoanee's Avatar
NCIX.com - Buy Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA775 LGA1156 120MM - RR-B10-212P-GP In Canada.
heatware
Old January 3, 2010, 03:13 PM
0o0 0o0 is offline
2nd hand true 120 or hyper 212+
Old January 3, 2010, 03:34 PM
dante1's Avatar
Actually I found that same heatsink before I even started this thread. It basically confirms that I should purchase it.
https://www.bestdirect.ca/products/?...8427&kw=cooler
A few dollars cheaper but they also have the video card that I want at the lowest price around.
http://www.bestdirect.ca/products/22...-20R/SAPPHIRE/
Should I also get some case fans for some good air flow?
I am using an Ultra 500watt PSU. I hope that is enough wattage.
Thanks
Old January 3, 2010, 03:42 PM
stoanee's Avatar
500 watt may be cutting it close. I would suggest something like this:
Corsair TX 650W Power Supply w/ 120mm Fan at Memory Express Computers
heatware
Old January 3, 2010, 03:44 PM
dante1's Avatar
Yeah, I thought about that. Is there a software that can tell me the load on my PSU?
Old January 3, 2010, 03:56 PM
stoanee's Avatar
Very general indication, ballpark only. The quality of the psu is very important for the longevity of your parts.
eXtreme Power Supply Calculator
heatware
Old January 3, 2010, 04:01 PM
MarkOne's Avatar
google : antec psu calculator
Old January 3, 2010, 04:17 PM
dante1's Avatar
Thanks for all your help
Old January 3, 2010, 04:54 PM
Arinoth's Avatar
Hands down the cooler master hyper 212+ for the price and the amount of cooling you get its great
Here I am: here I remain
cpu fan speed kromesta Air Cooling 4 August 15, 2009 08:27 AM
CPU cooler with no fan Caldezar Air Cooling 4 July 22, 2009 01:38 PM
Help! CPU fan not working! Waldie Troubleshooting 29 May 4, 2009 09:55 AM
GTX480 Fan Recommendations Infiniti Water Cooling 26 July 17, 2008 10:57 AM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
