Old December 27, 2009, 07:52 AM
Default Xigmatek HDT-D1284
Would this be a good cooler for socket 775 in a low profile htpc case?
Old December 27, 2009, 08:02 AM
Snafu's Avatar
I did not notice any marked improvement with the "Direct Touch" technology as compared to other coolers with standard heat-pipes through the base. Xigmatek has however, changed the base on newer coolers so that it is now machined smoother. Perhaps these newer coolers will perform better?
Some try to not use a fan on the cooler in an HTPC to reduce noise even more. Are you planning on using a fan on the cooler? If you then you might want to check out how well this cooler performs without a fan against other coolers.
Newest system: Intel E8400, Gigabyte EP35-DS3P, OCZ PC2-9200 Reapers, Seagate 3GB/s HDD, etc.
Others are kicking around the house.
Best fan for HDT-D1284 JD Air Cooling 8 August 8, 2009 09:33 AM
[FS] Xigmatek HDT-S1283V Dark Knight Mike_E Buy/Sell & Trade 8 July 28, 2009 08:53 AM
Xigmatek Achilles S1284 HDT CPU Cooler Hardware Canucks Air Cooling 0 May 7, 2008 01:31 PM
Big Typhoon VX & Xigmatek HDT-D1284 Hardware Canucks Reviews & Articles from the Web 0 April 24, 2008 05:20 PM
Xigmatek HDT-S1283 CasheKicker Water Cooling 0 February 19, 2008 02:26 PM
