I bought 6 of these to mount on my new rad:
GELID Silent12 PWM 750-1500RPM Power Management Speed Control GELID Silent12 PWM 750-1500RPM Intellegent Speed Control Fan [GELID Silent12 PWM] - $7.99 : DazMode, Watercooling enthusiasts store
These are 4-pin PWM fans. My intention was the mount six of these on my rad. I realized that they were PWM, but I assumed (incorrectly) that they would come with adapters for 3-pin or even molex. The fans came with neither. My mistake I guess.
I have a few questions:
1. Is it possible to attach these to a molex connector?
I do have some 3-pin to molex adapters that came with other fans lying around, but the 4-pin is too wide to fit. If I pried the 3-pin adapter open (ie. by forcing the 4-pin into the 3-pin adapter), will the pins on the 4-pin line up with the proper wires?
This is the 4-pin pwm connector on the fan:
Ie. this is the 3-pin adapter I have. I would have to bend/break the white plastic housing on the 3-pin side to physically fit the PWM connector:
2. If this will work, will the fan run at full speed?
3. If this will not work, is there something I can do to get these 6 fans running full speed on the rad?
Thanks guys! (btw posted in the 'Air Cooling' section because it is a fan question, even though it will be used in a WC setup. :) )
