Old December 11, 2009, 10:12 AM
Default fan choice for case and cpu cooler help
i'm looking for 6 cheap fans (4 for case in antec 900, 2 for the Mugen II cooler)
so far i've found 4 type of fans that fit the buget i'm on
CoolerMaster R4-L2R-20CG-GD (Coolermaster R4-L2R-20CG 120CM Green LED Case Fan 2000RPM 90CFM 19DBA 3/4 Pin - DirectCanada)
Zalman ZM-F3 (Zalman ZM-F3 120MM Sleeve Bearing Case Fan Black 900/1800RPM 20/34DBA 3PIN Connector - DirectCanada)
Scythe Slip Stream Kaze Jyuni 1200RPM (Scythe Slip Stream Kaze Jyuni 120MM Fan 1200RPM 68.5CFM 24DBA - DirectCanada)
Scythe Ultra Kaze 2000RPM (Scythe Ultra Kaze 120MM High Static Pressure Silent Fan 38MM 2000RPM 87.6CFM 32.9DBA - DirectCanada)
of these 4 fans, could someone is good experience and knowledge suggest me 4 for my case and the other 2 for my Mugen II cooler. what i'm looking for is performance with reasonable dba. if you have any better fans to suggest then go ahead but no more then 8CAD before tax for the fan.
Old December 11, 2009, 10:18 AM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
r4s are hard to beat...but they are loud at 12v. Same goes for yate loons. sleeve fans are "meh". The slip streams make decent case fans. Might want to look at Geil's they have decent dba, decent cfm and some are cheap ;)
Old December 11, 2009, 10:22 AM
Slipstreams for the case, Ultra Kaze for the heatsink.
CPU cooler with no fan Caldezar Air Cooling 4 July 22, 2009 01:38 PM
antec sonata case + cpu cooler xrayguy New Builds 1 July 21, 2009 07:48 PM
[FS] Antec P180 Case, Gelid Silent Spirit CPU Cooler element291 Buy/Sell & Trade 28 February 13, 2009 08:10 AM
Heatsink/Fan choice Mr. Gruntsworthy Air Cooling 34 September 24, 2008 12:31 PM
CoolerMaster Hyper212 Dual-Fan CPU Cooler Review Hardware Canucks Reviews & Articles from the Web 0 April 24, 2008 05:20 PM
