Old December 10, 2009, 03:14 PM
freaked's Avatar
Default Recommend me a CPU heatsink for a microfly case
Looking for a good CPU heatsink that will fit in a microfly case with a Asus M4A785-M motherboard with a AMD Phenom II X2 550BE CPU. I'm not going to mod the case, so I guess I'm left with the low-profile style coolers similar to the Thermaltake Blue Orb II.
Also it does'nt matter if the height of it blocks the tray from sliding open.
So, what are the better choices out there?
Could you guys recommend a CPU heatsink? Airshehan Air Cooling 37 March 10, 2013 08:47 AM
Inexpensive HTPC case... what do you recommend? redman HTPC Systems & Software 6 September 1, 2009 06:54 PM
Recommend a CHEAP and GOOD HTPC case for me please! Jamz HTPC Systems & Software 8 September 23, 2008 08:08 AM
which CPU do you recommend? vblanche CPU's and Motherboards 23 September 15, 2007 09:34 AM
Please Recommend a Case for my Needs SKYMTL Cases 21 August 29, 2007 09:41 AM
