Old December 6, 2009, 11:27 AM
Default Ultra Kaze Fans in CM690 - Insane airflow!!
Hi Everyone, Long time lurker but a new register... Love this place, its an amazing source of information.
So I thought I would share, I just picked up 5x Ultra Kaze 120mm 2000rpm fans (Canada Computers) and installed them into my cm690. What a world of difference these fans have made, I hooked them up to a fan controller and at full tilt 2000rpm my q6600 OC to 3Ghz (1.43vcore in bios) peaks 27c idle and under full 100% load in Prime it peaks at 47c. ( I can OC to 3.4, but see no real improvement in my score, so I reduced it for 24/7 use). Running my ram at 5-4-4-15-2t and 2.1v.
Basically in my cm690 I mounted them as follows:
2 - Ultra Kaze's - top (Exhaust)
1 - Ultra Kaze - Rear (Exhaust)
1 - Ultra Kaze - Bottom (Intake)
1 - Ultra Kaze - front (Intake)
1 - Coolermaster - Side Top (exhaust)
1 - Coolermaster - Side Bottom (Intake)
I would recommend these fans to anyone, at full tilt they are a little loud, but when I dial them back they are quite tolerable and still move more air then the stock coolermaster fans.
Cheers!
Old December 6, 2009, 02:38 PM
gingerbee's Avatar
jmo. but there the best fan for airflow for under 10 bucks$
Old December 6, 2009, 04:02 PM
I just happened to be driving by and I stopped in and picked these over the others they had on the shelf on a whim. Researched them today and I am impressed.
Old December 6, 2009, 04:15 PM
Soultribunal's Avatar
They are good fans for sure. I am a true Fan (no pun intended) of CM's new R4 lineup as well for both their subtle LED colour and the amazing amount of air they push as well.
Good Choice,
ST
Old December 6, 2009, 06:37 PM
5 of them. How's the noise?
Intel Core i7 920 4.1GHz w/ Thermalright U-120E
24GB G.Skill 1.25v DDR3-1600 9-9-9-24
eVGA 758 - A1
80GB Intel X25-M G2
1TB WD Black
1.5TB Seagate 7200.11 (still works!)
10.9TB RAID6 Samsung F4EG
XFX 5850 @ 1000/1250 w/ Scythe Setsugen
2X Dell U2412M Seasonic M12 850W
Old December 6, 2009, 06:52 PM
Not bad really when on the controller, if I let them rip full tilt its a little noisy but nothing my speakers cant drown out or headphones. When I undervolt them the northbridge fan is actually noisier, then again it is a different pitch.
I think removing the honeycomb grilling on the top and front would alleviate alot of the turbulence but I dont really wanna cut up my case even though I only paid 49 bucks for it.
Old December 6, 2009, 08:51 PM
kaze fans are junk.
they are only good if you undervolt them and doing so can lead to a ticking fan.
panaflo or delta ftw.
Old December 7, 2009, 05:07 AM
Originally Posted by enaberif View Post
kaze fans are junk.
Thanks for sharing your opinion, I've found a link when I researched them the other day and it was barely noticeable at 1m away, which my case is over 1m away from my ears in my seating position, so i couldnt care less if they tick slightly which mine are not... ( yet :). heheh. ) Panaflow and Delta are definately nice fans, but when I am filling a case with them (7); the fans would of cost more then the case housing them and I usually rebuild my rig every year or two so by then if the fans are ticking, so be it, they'll be recycled or given away.
I wanted huge airflow, for little investment and these fit the bill nicely. Which model of the Panaflow / delta are you running? (I jacked my own thread.)
Old December 7, 2009, 10:11 PM
CroSsFiRe2009's Avatar
Dunno if its the same but the 1200rpm scythe slipstreams are pretty quiet. While were on the topic of fans ftw, scythe s-flex :D
[FS] Thermalright 120 Extreme, Ultra Kaze 3000, Blue LED mhw100 Buy/Sell & Trade 14 May 19, 2009 03:49 PM
OMG such bad luck. Kaze screen doesnt turn on :( arekieh Troubleshooting 7 November 25, 2008 07:09 PM
my cm690 airflow? CTA Air Cooling 15 September 6, 2008 12:35 AM
Scythe Slip Stream Kaze Jyuni stormkiller22 Troubleshooting 4 March 8, 2008 02:10 PM
scythe ultra kaze are BAD for overvolting!!! solaris10 Water Cooling 1 February 1, 2008 10:14 AM
