<~----> Lamptron FC-5 prototype gets the go ahead for launch! - Hardware Canucks
Old November 30, 2009, 10:40 PM
Spawne32's Avatar
Manufacturer Rep
Default Lamptron FC-5 prototype gets the go ahead for launch!
Got the second prototypes in today, everything checked out great, all of the issues regarding the RPM sensors, voltage sensors, and LCD viewing angles have been corrected, and the go ahead for product launch has been given, you should be seeing these bad boys hit store shelves very soon!
Of course, remember you can always follow Lamptron on both facebook and twitter...
Lamptron (Lamptron) on Twitter or search lamptron on facebook and become a fan!
Old November 30, 2009, 11:47 PM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
How do the knobs feel? I hate knobs that feel hollow and cheap...and that come off.
Old November 30, 2009, 11:57 PM
Spawne32's Avatar
Manufacturer Rep
aluminum capped, inner material is a poly/abs plastic, they feel very solid when using, and of course they are removable should you want to use custom knobs
Old December 1, 2009, 12:00 AM
MAC's Avatar
MAC MAC is offline
Ah, sounds good.
By 'come off', I mean't inadvertently due to overly loose knobs
Old December 1, 2009, 12:03 AM
Spawne32's Avatar
Manufacturer Rep
Originally Posted by MAC View Post
Ah, sounds good.
lol nah these are in no way cheap like that, part of my job is quality control, so if theres a design flaw that makes them loose, it would have been corrected before release.
Old December 1, 2009, 06:10 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Looks amazing but it looks like there is still some color crossover / bleed from the lighter LED settings which makes the blue and purple a bit hard to read.
Can you show us the internals? How many watts per fan does it support?
Old December 1, 2009, 09:50 AM
Spawne32's Avatar
Manufacturer Rep
The color crossover only is visible in extremely dark conditions, in order to keep the cost down we steered away from the TFT active matrix display. Normal lighting conditions it was perfectly fine. Ill get you the other information today.
Old December 1, 2009, 10:06 AM
Soultribunal's Avatar
Yeah I'd love to know the wattage limit per Channel as well as what faceplate colours does it come in.
After all, Black is the most common as well as Silver but there are some nice White cases still on the markets.
Regards,
ST
Old December 1, 2009, 06:12 PM
Spawne32's Avatar
Manufacturer Rep
Regards,
ST
The unit itself can handle up to 30w per channel, and to my knowledge there are no plans to make a white version of the FC-5, right now its black and silver.
Old December 1, 2009, 06:18 PM
WOw, it can handle even my San Aces at that rate.
Availability in Canada?
ST
Lamptron FC-2 fan controller mod (so it looks nicer on cases) IKIKUINTHENUTZ Cases 5 July 22, 2009 05:17 PM
Prototype Spikemaul Gaming 61 June 26, 2009 07:51 PM
'09 PC games. A look ahead. Alwaysrun Gaming 30 January 3, 2009 06:18 PM
AMD: The Road Ahead by Anandtech Babrbarossa CPU's and Motherboards 16 October 23, 2007 07:13 PM
New OCZ HydroJet CPU Cooler Prototype! Apollo4g Water Cooling 6 October 21, 2007 12:35 AM
