Two questions: see inside for details Hey all, didn't feel like starting 2 threads for 2 different questions so I'll ask them both here: 1. What's a good (inexpensive) low profile heatsink that is compatible with amd cpu's? [looking for recommendations] 2. Whats a good (inexpensive) 80mm fan that can move air and also stay quiet when things heat up? EDIT: make that 3 questions 3. Any good vga coolers out there that are compatible with low profile cards? |
Epic Ghetto Low profile heatsink: Stock AMD + MX2 + NCIX.com - Buy Nexus 80MM & 92MM to 120MM Fan Mount Adapter - 120MM-ADAPT In Canada. + Some 120mm Fan??? |
I'm using this in my HTPC and it is silent. Easy to install and cools well. A quick pricematch check shows it can be had for $31. NCIX.com - Buy Scythe Shuriken 3 Heatpipe Low Profile CPU Heatsink LGA1366 1156 775 AM2+ AM3 939 940 W/100MM Fan - SCSK-1100 In Canada. |
As for 80MM Fans Well you will be hampered because that profile will give you two real options. 1 it moves high CFM but makes a racket (TT Smart Fans are good for this) 2 it is quiet as a mouse but moves less than ideal air. There are some cheap LED ones that I like by Masscool, or TT... It all depends, can you fit a 80-120mm adaptor in there? ST |
How bout my idea -_-??? Will it work? |
Those are some good ideas. The scythe shuiriken looks especially promising, I'll see if I can find in @ canadacomputers for a reasonable price. ST, I think it would be impossible to fit in a 120mm fan using an adapter. I am using this case : ::::::::::IN WIN:::::::::: |
Then I'd suggest these fans Cowboy, Buy the Enermax UC-MA8 Magma 80mm Case Fan at TigerDirect.ca ST |
thanks. I'll try to see if I can find it locally. |
Zalman CNPS8000 Low Profile Heat Pipe CPU Cooler - Page 1 of 7 - Big Bruin I have this exact fan HSF it works really well. |
CC usually carries Enermax Fans too. So if you can find their LED versions there they should be just as good. I have slowly come to like Enermax for the fans they have. ST |
| All times are GMT -7. The time now is 01:12 AM. |
