Old November 30, 2009, 03:11 PM
Default Green LED Fans
Hey guys,
Im currently thinking about starting an all green theme'd Coolermaster HAF 932 case. I may even be getting a guy to powdercoat it, may make it Nvidia theme'd. But im not sure yet on all the details =/
However to start i know exactly what i want to do for my Fan setup, but i could definatly use some advice on what fans i should get. On the mesh side of the case im thinking along the lines of 4 Green LED fans, just a quick look onto NCIX and i saw NCIX.com - Buy Coolermaster R4-L2R-20CG 120CM Green LED Case Fan 2000RPM 90CFM 19DBA 3/4 Pin - R4-L2R-20CG In Canada. but i dont know if these would be the best choice.
I would also love to replace the huge top fan with an green LED as well, and the front and back fans. Any suggestions you guys have would be awsome!
Old November 30, 2009, 05:56 PM
Soultribunal's Avatar
Coolermaster R4 Fans are Awesome!! I am the proud owner of about 10 Blue LED ones and they are a great balance of price/performance/noise/style.
Best choices IMO.
ST
Old November 30, 2009, 06:09 PM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
R4s are sweet fans. Very similar to the BladeMaster which comes with the Hyper 212+. ;)
No idea on the front (its a PITA to remove), but I yanked the top one and stuck in three Noctua's NF-p12-1300s.
Old November 30, 2009, 10:22 PM
Technokat's Avatar
what about gelid fans, they make green ones too
ps. Oh they are uv, not led, sorry :)
Old December 1, 2009, 01:24 AM
almighty guys thanks so much for confirming that these would be some good fans =D. Ill probably order them within the next week or two when I get a new monitor for the rest of my folks to use (shhh dont tell them its for Christmas!)
Plus ill defiantly get some pics up when i get it all going!
Old December 1, 2009, 01:27 AM
I used both 120mm Coolermaster and 120mm Thermaltake thunderblade green led fans on my recent build seen here. I also used a Hiper.
http://www.hardwarecanucks.com/forum...n-machine.html
Old December 1, 2009, 10:57 AM
You can chop the price in half for the R4's if you pricematch off bestdirect.ca
Green 120mm fans - Need halp! Lamb Air Cooling 3 July 22, 2009 02:09 AM
Lighting case mod any good without led fans? dosmond Cases 3 June 27, 2009 05:40 PM
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
Cooler Master LED Fans JD Air Cooling 7 June 17, 2009 12:49 PM
FS:Zalman CNPS9500 LED Copper CPU Heatsink 92MM Fan 1350-2600RPM 18-27.5DBA Blue LED oksir Buy/Sell & Trade 0 July 14, 2008 12:24 AM
