Old November 22, 2009, 02:54 PM
Luckk's Avatar
Default Thermal Paste?
What is thermal paste needed for? And is it necessary when buying a heatsink like the Coolermaster Hyper 212+ ?
Newbie! Over 9000. I'll burn your house down. Oh Hell Nah Hol' My Earrang. No, you! (WoW player, looking to play some Crysis, etc... once a new, better computer is built)
Old November 22, 2009, 03:10 PM
MarkOne's Avatar
. it's for transmit the heat from the cpu to the cooler. yes you need them with any cooler .but it's probably include with the 212+ .. I remember, I was the only one in my work place to use them with 486, at the time I said if it's good for 1 transistor.. it's must be good for millions of them .
Old November 22, 2009, 03:11 PM
Sushi Warrior's Avatar
Thermal paste is used for adding some heat transfer in the flaws between the heatsink+CPU. It's EXTREMELY necessary and you will almost always overheat without it. MX-2, Noctua paste, and the Gelid stuff are all pretty good.
Old November 22, 2009, 03:18 PM
kendallcschm's Avatar
it helps transfer heat.. and that isn't the best of fans on the market.... what kind of CPU are you using it for?
Old November 22, 2009, 03:24 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
The Hyper 212+ comes with a small tube of CM branded TIM, but I would recommend chucking it and getting some MX-2. The 212+ may not be the "best" cooler on the market but it is one of the the best (if not the best) Bang for your buck coolers going. IMHO its a great investment unless you are going for monster OC...then get a Prolimatech, Zalman Flex or (if you can find it) a Titan Fenrir.
Old November 22, 2009, 04:34 PM
Luckk's Avatar
myself am buying one of the new AMD Phenom X4 965 120w. Think that will be sufficient if I try to overclock it to atleast 3.8?
Old November 22, 2009, 05:19 PM
MarkOne's Avatar
4.0 must be the goal
Old November 22, 2009, 05:39 PM
Luckk's Avatar
Hehe well I don't think ill be able to get 4.0 with only 4g of GSkill 1800 DDR3 ram or on air cooling(unless im wrong?) So would the Coolermaster Hyper 212+ be sufficient along with my Antec P193?
Old November 22, 2009, 06:14 PM
AkG's Avatar
AkG AkG is offline
It will be pushing it to its limits. High OC on a high TDP cpu = beefy HS&F needed. What is your budget?
The Zalman Flex is on sale for like 40 bucks at ncix. Drop a Scythe G (or pair of them) on it and you should be golden (or a pair of Yate Loons).
NCIX.com - Buy Zalman CNPS10X Flex CPU Cooler LGA1156 1366 775 AM3 754 939 940 Support Dual Fans - CNPS10X FLEX In Canada.
Old November 22, 2009, 06:45 PM
Luckk's Avatar
Budget would be like 100$ I would say.
Thermal Paste question CV2010 New Builds 13 October 14, 2009 10:46 PM
Thermal Paste miggs78 Water Cooling 4 September 10, 2009 07:17 PM
Amount of thermal paste - help Chris Air Cooling 6 June 17, 2009 05:18 PM
Thermal paste comparison Technokat Overclocking, Tweaking and Benchmarking 3 April 7, 2009 08:12 PM
Thermal Paste??? Salavat23 Water Cooling 6 December 27, 2007 06:43 PM
