Old November 8, 2009, 11:51 AM
jcmaz's Avatar
Default Sub $20 HSF Opinions
I've started to overclock my AMD 5200+ to 3.0Ghz on the crappy stock heatsink. So i'm in the market for a better aftermarket HSF.
Looking at NCIX's inventory of HSFs, i found these three ~$20 HSF, all with heatpipes like the popular 212+. So here are the HSF:
AeroCool DCC-C900 LGA775 AM2/AM3 Direct Touch Heatpipe Cooler 800-1500RPM 120MM Fan
Coolermaster RR-910-HTX3-GP Hyper TX Series Aluminum 3-HEATPIPE CPU Cooler S1156/775/AM3/AM2/939/940
OCZ Vendetta Heatpipe CPU Heatsink AM2 LGA775 S939 S940 S754 92MM 1200-2800RPM
Silenx iXtrema Pro Direct Touch Heatpipe Cooler LGA775 LGA1366 AM3 with 92MM 2000RPM 18DBA LED Fan
My question is, which one would be the best bang for the buck?
-Plato
Old November 8, 2009, 12:39 PM
Vandetta, but you could easily get a 212+ for $25. Either or would be a solid choice.
Old November 8, 2009, 12:50 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Honestly, none of those coolers are worth it UNLESS 20 bucks is your max budget. IMHO spend a few extra and get either a Vendetta 2 or Hyper 212+.
IF I had to chose between those 4, Id probably go for the OCZ Vendetta, it may only use a 92mm fan but it is a decent cooler at lower thermal loads....that or the Aerocool, because it uses a 120mm and thus is easier to swap out the stock fan for a better low noise / high performance fan. BUT it would be chose one of those four or use the stock cooler kind of deal. :)
Old November 8, 2009, 12:59 PM
Soultribunal's Avatar
Aero or Vendetta if really all you can spend is 20.
However its best to spend a bit more , as AKG said and get something like teh CM 212+.
Regards,
ST
www.realhardwarereviews.com
Old November 8, 2009, 01:08 PM
Dr_BenD_over's Avatar
Fallen Folder
I personally wouldn't trust anything made by SilenX to cool my CPU. I'm at a 57% failure rate with their fans...
All's well that's Haswell
Old November 8, 2009, 01:15 PM
Arinoth's Avatar
I agree with the others here, spend the little extra cash and pick up a tried and tested CM 212+ or Vendetta 2
Here I am: here I remain
Old November 8, 2009, 01:17 PM
And it's not like their fans are cheap $$$.
Back to subject, spend extra $5 and get 212+. You can use it when you upgrade later on.
"What is the colour when black is burnt ?" - Neil Young
Old November 8, 2009, 01:53 PM
jcmaz's Avatar
I know that the 212+ is good, but that requires me to take out everything (pain in behind). Also, i cannot PM coz i don't have a CC. How bout the Coolermaster HSF, it is the little bro to the 212+. and you are able to use to 2 fans instead of one.
-Plato
Old November 8, 2009, 02:00 PM
Perineum's Avatar
The 212 is where it's at.... at it too allows you to use 2 fans
Old November 8, 2009, 07:49 PM
Kayen's Avatar
Don't be lazy. Get a hyper 212 .. mattlef has one for sale .
Best HSF for a P2 955? ADay2Long Air Cooling 7 August 4, 2009 01:06 PM
Best hsf for e8400 !? CraigHf Air Cooling 22 December 18, 2008 02:03 PM
Looking for HTPC case and HSF Cypher^64 HTPC Systems & Software 7 November 10, 2008 09:39 PM
FS: HSF Enzotech EXTREME-X core2strike Buy/Sell & Trade 16 August 10, 2008 01:30 PM
which is the btter hsf? v0maru Water Cooling 10 January 17, 2008 06:16 PM
