Old November 5, 2009, 11:23 AM
Fudd Rucker's Avatar
Default What fans to use
I seem to have accumulated a lot of nice 120mm fans and was wondering what the best 2 would be to plant on my noctua for best performance. My list of fans are as following
5 x yate loon 47CFM 1350rpm
2 x slfex 67cfm
2 x stock noctua fans that came with my noctua
2 x lian li 60cfm 1300rpm fans
Now my question is, which are the best 2 to use for a push pull config with maximum possible static pressure on the heatsink.
I couldnt think of something snarky or interesting to put here this time around.
Old November 5, 2009, 11:46 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Is noise an issue for you? Those Sflex's are the "f" model 1600rpm. Very good fans but not exactly low noise. They would be my first choice.
The YL D12SL are good for their price BUT IIRC they have less static pressure than the noctuas (1.1 vs 1.6). So the Noctua's would be next choice.
Never tried the Lian Lis (no idea what model number you are talking about) thus can not comment one way or the other.
Scythe > Noctua > YL
Lian li unknown
Old November 5, 2009, 11:56 AM
Soultribunal's Avatar
I think I know the Lian Li fans your talking about, I would go with the YL's or the Lian Li's for sure.
I love both their fans equally.
ST
www.realhardwarereviews.com
Old November 5, 2009, 01:05 PM
Gave my friend the set of no name lian li fans I had. Going to go with the Sflex fans as i figured those would be the best, but was looking for a good response to why.Going to use the yate loons for case fans for now, then probably change them to the noctua fans when i go back to watercooling .This is only temp as I just to scrape up a few bucks for a Heatkiller 3.0 for 1156 and a good pump to go back to watercooling again.
Thanks for the help everyone
Old November 5, 2009, 02:33 PM
Sushi Warrior's Avatar
I would say SFLEX for performance, Noctua for silence. The noctuas are good fans (but hugely overpriced), quieter than the SFLEX F's but will not pish as much air.
Old November 5, 2009, 03:17 PM
gentle typhoons, quiet, high cfm and high static pressure, what more could you need?
EDIT: aha didnt read first post, sflexs for max performance
Old November 5, 2009, 04:27 PM
Noctua for push and SFlex to pull. That's if you don't mind the colour mis match
"What is the colour when black is burnt ?" - Neil Young
Old November 5, 2009, 04:46 PM
I wouldn't do that, in theory matching up 2 different fans with different pressures and airflow rates will cause any number of problems.
Old November 5, 2009, 04:53 PM
AkG's Avatar
AkG AkG is offline
IMHO bad idea, you would get all the noise of the Sflex F....without the performance.
Old November 5, 2009, 04:54 PM
I was under the impression you were better off using the same fans for a push-pull or are you meaning push as in exhaust and pull as in intake ?
Alright, would u mind explaining because I am very interested in this thread and that answer puzzles me.
[FS] WC and Fans Jackquelegs Buy/Sell & Trade 16 December 8, 2009 09:47 AM
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
Anyone have one of these fans? Realityshift Air Cooling 11 March 12, 2009 08:44 PM
What are the quietest fans? Sniper Off Topic 20 June 3, 2008 01:36 PM
Fans for WC and tubing Dashock Water Cooling 7 May 5, 2008 10:13 AM
