  #21 (permalink)
Old November 5, 2009, 05:38 AM
martin_metal_88's Avatar
But there is a big point for noctua, I really love their back plate. Covered with full rubber it's genius.
  #22 (permalink)
Old November 5, 2009, 09:12 AM
Fudd Rucker's Avatar
Thats why this heatsink is suppposed to be 79 bucks,because its a solid sturdy unit with top notch installing hardware.
I couldnt think of something snarky or interesting to put here this time around.
  #23 (permalink)
Old November 5, 2009, 09:33 AM
MarkOne's Avatar
I have this cooler on my squeleton , no choice it's on of the best that fit there , all true I have to cut the frame of the Antec a little bit..the cpu is a e8400, I rise it until 4 ghz without problem, not it's stock. the only thing I did was to dremel the center of the back plate, I was worry to not clear enough that cap or clock thing at the pack of the asus board. No I want to find a better looking fan for it. all true the Noctua fan is very silent came with choice of online resistor for the speed. But the color
  #24 (permalink)
Old November 5, 2009, 10:12 AM
Well, for silent Gelid 1300RMP ( the PWM for a CPU cooler )
NCIX.com - Buy GELID Solutions GELID Silent 12 PWM 750-1500RPM 120MM PWM Control Fan 58CFM 12-25.5DBA HDB 4PIN - FN-PX12-15 In Canada..
Or the scythe slip stream they are also really good and quiet.
NCIX.com - Buy Scythe Slip Stream Kaze Jyuni 120MM Fan 1200RPM 68.5CFM 24DBA - SY1225SL12M In Canada.
These 2 guys are dead silent and have a good airflow. With that your noctual should be silent and have a better look, I can understand that brown and a kind of pink is a little weird on a skeleton.
  #25 (permalink)
Old November 5, 2009, 10:58 AM
MarkOne's Avatar
thanks Martin, i take good note , it's 2 months I have the Noctua , take note than I see no difference in temps , with no resistor and the one to set at midle speed ( don't remember the color will check tonight,) all true the Squeleton huge fan blow half of the Noctua
every time I order something some place I always forgot the fans, I need few also for cases
  #26 (permalink)
Old November 5, 2009, 06:57 PM
Slipstreams are great fans, but they have low static pressure which makes them not that well-suited for use with heatsinks. A better choice would be the Scythe Gentle Typhoon fans, which although they don't perform quite as well as Slipstreams, are still some of the best fans out there and are better for heatsinks.
Ask for more.
[WTB] Noctua NH-U12P 1366 stuff trayton Buy/Sell & Trade 1 October 26, 2009 07:21 AM
Noctua NH-U12P or TRUE 13RT? Digikid Air Cooling 28 February 6, 2009 04:43 PM
PCFlip Giveaway - Noctua NH-U12P SEI1366 Salavat23 Off Topic 0 February 2, 2009 08:49 PM
Just got Noctua NH U12P 1366 appplejack Air Cooling 16 December 26, 2008 04:52 PM
Noctua NH-U12P Heatpipe CPU Cooler Hardware Canucks Air Cooling 0 May 5, 2008 12:32 PM
