Old October 31, 2009, 05:43 PM
Lima's Avatar
Default Double sided tape for backplate.
Hi peeps.
I had removed my crossbow back plate when I had to RMA my motherboard and now I have to replace the tape. Anything to look for or can I just use any double sided type from the hardware store?
Old October 31, 2009, 06:10 PM
lowfat's Avatar
I don't even see why they come w/ tape. Its not as if the backplate moves around. Just put something in place so it doesn't ground out. Taping something to the motherboard that will always need to be removed later on seems like an awful idea to me
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old October 31, 2009, 06:22 PM
Lima's Avatar
Well, I'll let you know why I want to replace the tape.
I removed the cooler many times and never had to remove my motherboard to hold the back plate while trying to screw the cooler back on. I wouldn't even want to imagine putting it back on without the tape to hold it there.
What I am really wondering, is if there are non conductive tapes that I should look for.
Old October 31, 2009, 07:30 PM
JD JD is offline
I'm fairly sure any double sided tape will work. You might want to get the foam kind just in case the board has some solder points where the tape covers.
Old October 31, 2009, 07:36 PM
If you re-mount the backplate carefully you won't need tape.. Even the TRUE back plates that instruct you to peel off and use the sticky stuff, which is a royal PITA to get off, I just use it as it is.. just put something foamy at the back..
Old October 31, 2009, 07:39 PM
come over i'll give you as much as you want for free
anyone else need good 3m tape lol
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old October 31, 2009, 08:32 PM
martin_metal_88's Avatar
I have done it one time, what I have done is the cover all the back of the socket with electrical tape. Work fine easy to remove ( at the time it get hot it wont stick any more so it stay here by the screw tightness ) It work fine for me.
Ask for more.
Old October 31, 2009, 08:45 PM
Lima's Avatar
Thanks guys, much appreciated.
@ martin_metal_88
That's a nice trick man!
@ zsamz_
I guess I'll be seeing you soon
Double Checking my Shopping List AmuseMe Water Cooling 15 October 12, 2009 05:20 PM
double sided laser printer? elninio Peripherals 2 March 14, 2009 11:19 AM
wow double post Phobia Off Topic 0 January 29, 2009 12:23 AM
Double sided thermal tape at NCIX Babrbarossa Water Cooling 10 October 31, 2008 12:06 AM
How to Maintain a stable Crucial Ballisitix PC2 8500 double sided Overclock rom0n Overclocking, Tweaking and Benchmarking 7 May 11, 2008 04:41 PM
