Old October 17, 2009, 07:46 AM
Slik's Avatar
Default Thin exhaust fan?
I own a Dell XPS 730X desk top with not much room in it for add on interior fans etc. Of all those fans that I have looked at, none are thin enough to install for rear exhaust, They are all about 1 inch thick. A half inch would fit perfectly. Anyone ever heard of one? Thanks.
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
Old October 17, 2009, 09:08 AM
JD JD is offline
What's the width of the opening? 120mm? 92mm? 80mm?
25mm thickness is standard for all case fans, and there are 15mm variants which might fit.
Old October 17, 2009, 12:23 PM
burebista's Avatar
Here you go.
I have one (1200 RPM model and kept @800 RPM by SpeedFan) in front on my P182 bottom HDD cage and they're OK.
Old October 17, 2009, 12:37 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
+1 to burebista's recommendation. I have used those fans as well and for tight spaces, they are a good choice. Definitely good at lower speeds too :)
Old October 17, 2009, 03:47 PM
Soultribunal's Avatar
I second that opinion, they use that same fan on one of their downdraft coolers and they are really good.
Regards,
ST
www.realhardwarereviews.com
Old November 6, 2009, 06:26 AM
Slik's Avatar
Originally Posted by burebista View Post
Here you go.
Thanks , I found it and ordered last night.
Need thin wire... biff Off Topic 29 November 23, 2010 06:16 PM
How do I wire the exhaust fan to a slower speed? Shadowmeph Air Cooling 8 April 25, 2009 02:56 PM
Is rear exhaust fan really needed? aviduser Cases 18 March 27, 2009 11:49 AM
MM Horizon Exhaust Fans Question zlojack Water Cooling 5 March 2, 2009 10:13 AM
Need a Very Thin and light, 15" LCD, VGA or DVI Cptn Vortex Display Units 0 December 11, 2007 01:08 PM
