Old October 15, 2009, 08:52 PM
geokilla's Avatar
Default Cleaning AS5 and Temperature
The best method to clean AS5 is to use lint free cloth. I've read that coffee filters are the best and cheapest way to clean AS5. However, today I had to clean it using q-tip because I don't have any lint-free cloth. Is there a problem with that? I used 70% isopropyl alcohol and q-tip to remove the old AS5 and applied new AS5. I hope I had the right amount.
As for the temperatures. Does 53C F@H load temperatures for a AMD X2 3800+ @ 2.6Ghz with 1.38Vcore (CPU-Z) seem right to you? In the BIOS, the Vcore is set at 1.5V, but I seem to have quite a bit of undervolting going on with my M2N-E. I absolutely hate this motherboard.
Old October 16, 2009, 05:53 AM
gingerbee's Avatar
that's what i use all the time just be careful
Old October 16, 2009, 06:37 AM
martin_metal_88's Avatar
+1 that's what I use all the time and also the little round thing your GF use to remove the paint she put in her face every morning. it's expensive to the bone for cotton but do a great job and absorb all the propylene alcohol. At job we are also using a monitor cleaning towel witch do a pretty good job but, once it's all dirty...trash is the only option.
Ask for more.
Old October 16, 2009, 08:03 AM
MpG's Avatar
MpG MpG is offline
Technically 99% iso is better, simply because you don't have to wonder what the remaining 30% is composed of. Q-tips are fine too, as long as you don't leave any cotton strands behind in the process.
Old October 16, 2009, 06:03 PM
geokilla's Avatar
Hmm there's definitely cotton left behind, but I try to clean it up as best as I can.
Old October 16, 2009, 07:08 PM
gingerbee's Avatar
being careful there should not be any left behind
Cleaning a loop miggs78 Water Cooling 11 July 9, 2009 10:14 AM
[FS] Cleaning Up my Closet lcdguy Buy/Sell & Trade 6 April 7, 2009 07:44 AM
[FS] Games, AS5, ski goggles! bojangles Buy/Sell & Trade 18 January 9, 2009 03:46 PM
Accelero S1 - Stock TIM or AS5 ? mattydies Air Cooling 3 February 14, 2008 09:27 PM
Using AS5 on Amd X2 4200 Dashock Overclocking, Tweaking and Benchmarking 0 January 8, 2008 10:15 AM
