Old October 12, 2009, 05:35 AM
Caldezar's Avatar
Default Need advice - mounting kit for S1283
So I picked up a Xigmatek 'Black Scorpion' the other day and set it up on my 550BE. So far it's been a great performing cooler, (and nearly dead silent) but I have one issue... It's mounted 90 degrees off! The only mounting option for AM2/AM3 that came with it is the plain bracket that clips to the on-board mounting frame. The trouble being, that the on-board frame on my MB has the clips in an up/down position. So the heatsink blows air straight up. Now, I'm lucky in that I have a nice large fan on the top of my case, so hot air is being effectively exhausted. But One of my RAM chips is covered by the fins of the cooler. (It's quite large)
Does anyone know of a mounting kit available for this cooler so I can turn it 90 degrees? I looked at the crossbow, but I can only find 775 versions of that one. I need an AM2/AM3 mounting kit. I'm also concerned about how the on-board bracket will handle the weight over time. I'd like to get this sorted out asap as I'd be choked if the plastic bracket snapped and I screw up my system...
Pic for reference:
Old October 12, 2009, 07:05 AM
martin_metal_88's Avatar
This is a reason why AMD people almost all go with CM hyper 212+ in my knowledge it's the only cooler witch can be mounted front to rear on a AMD setup. If I was you, I would turn it 180 degree so it wont suck up all the hot air.
Ask for more.
Old October 12, 2009, 07:36 AM
Caldezar's Avatar
If I flipped it 180 degrees, I'd be pulling air counter-intuitive to the exhaust at the top of the PC. Not to mention, I'd just be cycling air within the case.
Old October 12, 2009, 08:01 AM
Ah you are true my bad:P
Ask for more.
Old October 12, 2009, 08:40 AM
Caldezar's Avatar
So far the only good option I can find is the Prolimatech Megahalem cooler + AM2/AM3 kit... but I went with the red scorpion to try and avoid spending $100+ on a cooler... Might just have to leave it as is. Although I find it more than a little retarded that the majority of coolers only have AMD mounting as an afterthought.
Old October 12, 2009, 09:23 AM
Sushi Warrior's Avatar
From what I've read the mounting kits will allow you to turn it 90 degrees.
Old October 12, 2009, 09:56 AM
JD JD is offline
The Hyper 212 Plus would allow you to rotate it 90 degrees and it comes with a solid metal and screw mount. It's only like $20 which isn't that much more than a mounting kit for your current heatsink, which may or may not work.
Coolermaster Hyper 212 Plus AMD Installation & Clearance
Old October 12, 2009, 10:51 AM
Caldezar's Avatar
Yeah... the crossbow mounting kits for it are all for Intel platforms... and they work great. The problem is I can't find a mounting kit for AM2/AM3. If you find one, put up a link.
I just bought my cooler. And it's been installed, so I'm fairly certain I won't be able to return it to NCIX. I really don't want to turn around and buy another one.
At the end of the day, I suppose I can live with it as-is. My temps are pretty good unlocked with minor O/C'ing. And I don't O/C my RAM or GPU, so I'm not really concerned about their temps. (They're both quite cool) So I suppose It's more aesthetics at this point then anything... but still...
Old October 12, 2009, 07:26 PM
JD JD is offline
Understandable. But sometimes to get things to look right, you need to "waste" some money
And well I'd imagine you could sell it on here and make back some money.
Old October 13, 2009, 07:40 PM
JD JD is offline
Noticed this today: XIGMATEK
Which is precisely what you want
[WTB] Trying to find the LCLC AM2 mounting kit... CMetaphor Buy/Sell & Trade 5 August 6, 2009 05:03 AM
HDT-S1283 lazypanda Troubleshooting 4 July 30, 2009 11:11 PM
[FS] Swiftech Apogee GTZ CPU block 775 and 1366 Mounting kit donkon Buy/Sell & Trade 7 July 18, 2009 01:34 PM
Anyone need a dtek 1366 mounting kit? sheepdogexpress Water Cooling 1 December 6, 2008 05:39 AM
[FS] swiftech 240 rad with barbs and mounting kit 15eman Buy/Sell & Trade 4 December 5, 2008 02:45 PM
