  #41 (permalink)
Old October 12, 2009, 10:13 AM
somecanadianguy's Avatar
Why bother going through the hassle of selling the TRUE and getting an H50 before you at least see if you can get better temps with what you have?
The TRUE throws off a lot of heat which has to be exausted from the case.
I'm willing to bet that if you add some exaust fans and maybe another intake your temps should be fine.
  #42 (permalink)
Old October 12, 2009, 01:05 PM
i just did a test. I opened up side of my 800d letting lots of air in. At stock clocks my temps were in 50s at stress test on each core. CPU temp was 35. Weird thing is my CPU cooler felt cool. Does that mean it is not mounted properly? AlsoI did some research and apparently my fans have low static pressure which is not good for a heatsink
  #43 (permalink)
Old October 12, 2009, 03:33 PM
If the heatsink feels cool after use then there may very well be a mounting problem.
I can feel the heat from my TRUE through the side of the case.
  #44 (permalink)
Old October 12, 2009, 05:23 PM
It was when my temps were in the 40s at idle. I've remounted twice so I don't think its wrong. I think its just my fans low static pressure.
  #45 (permalink)
Old October 12, 2009, 06:37 PM
Did you check the base of the cooler with a razor blade to see if it needs a little work? I was reading some reviews on your case and one reviewer mentioned the design was bad for cpu cooling but never said anything about a fix. I'll see if I can find it again and post it. I never found the review I saw but here's a c/p from Hexus reviews that I found
"After an hour of stress-testing Corsair's Obsidian Series 800D gets surprisingly warm. Ambient chassis, CPU and GPU temperatures aren't the best we've ever seen, and we'd have expected better. Of course, the chassis does provide room for ample cooling expansion, but we'd have predicted better out-the-box performance".
  #46 (permalink)
Old October 14, 2009, 05:18 PM
well a little update, my system is running at 4ghz nice and stable:) bit warmer then wanted but all good. I have a 1.3 vcore and max temps at 75 under load. I will be replacing some fans though to lower the temps a bit:)
  #47 (permalink)
Old October 14, 2009, 06:39 PM
So did you end up keeping the TRUE?
  #48 (permalink)
Old October 15, 2009, 05:22 AM
yes I kept the TRUE. It runs around 10 degrees warmer then I want it right now but with new fans it should be ok
  #49 (permalink)
Old October 15, 2009, 06:29 AM
gingerbee's Avatar
75c is too high?
  #50 (permalink)
Old October 15, 2009, 07:44 AM
Arinoth's Avatar
Anything over 80C is when you want to potentially worry about but the threshold is 100C
Here I am: here I remain
not bad temps with 511's badatcards HardwareCanucks F@H Team 4 July 24, 2009 10:10 AM
DC - All that bad? JD Off Topic 16 December 24, 2008 08:27 AM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
Bad Ram?? Jarod_g29 RAM 9 February 26, 2008 11:33 AM
