  #31 (permalink)
Old October 10, 2009, 07:43 PM
gingerbee's Avatar
ya seems kinda weird mine c0 and it's in my sig I guess luck of the draw. try lowering it @3.4 and see how low you can go
  #32 (permalink)
Old October 11, 2009, 02:24 PM
Well I just lowered the volatge in eleet. Was able to get to 1.22vcore
but I didn't stress test to see if it's stable. I guessthe dummy oc is very generous in volatge.
  #33 (permalink)
Old October 11, 2009, 03:21 PM
gingerbee's Avatar
but I didn't stress test to see if it's stable. I guess the dummy oc is very generous in volatge.
they normally are
  #34 (permalink)
Old October 11, 2009, 07:12 PM
I just removed the side panel temps stayed the same. It seems like alot of air is being pushed from intake fan. Is that just air bounching of TRUE Though?
  #35 (permalink)
Old October 11, 2009, 08:11 PM
somecanadianguy's Avatar
How do you have your case fans set up?
Which way is the TRUE oriented?
  #36 (permalink)
Old October 11, 2009, 09:26 PM
Well I reseated it didn't help really temps are the same. I only have stock intake right now but am planning on replacing stock fans and putting 2 120mm fans on the top and a front intake. TRUE is North/South wince I can't do it East/West With my classified
  #37 (permalink)
Old October 11, 2009, 10:48 PM
Really does sound like a case airflow issue.
You definately need an outtake fan.
  #38 (permalink)
Old October 11, 2009, 10:52 PM
Uh if your true is blowing towards the top of the case.. and your not pulling the air out.. your doing more bad than good.
I'd personally pull the fan off the hot swap bay and stick it up there as a test.
  #39 (permalink)
Old October 11, 2009, 11:05 PM
Hotswap cooler is 140mm not 120. I think I will sell my TRUE as it is in the classifieds now and buy a h50. Then I can have in push/pull without too much of a worry for
airflow. I will add a front intake, replace stock fans and get a h50
  #40 (permalink)
Old October 11, 2009, 11:17 PM
So?
You can make it work temporary.
not bad temps with 511's badatcards HardwareCanucks F@H Team 4 July 24, 2009 10:10 AM
DC - All that bad? JD Off Topic 16 December 24, 2008 08:27 AM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
Bad Ram?? Jarod_g29 RAM 9 February 26, 2008 11:33 AM
