  #21 (permalink)
Old October 10, 2009, 05:59 PM
Originally Posted by Sushi Warrior View Post
But when overclocked, chips can die very easily. I have seen 6800GT's die at 58C. The extra voltage means the chip should stay lower. I would say 85C is a good mark for 1.35v+. Never hurts to be cautious.
A 6800GT is very different from a modern CPU. Like I said, there are protections in place to prevent damage from occurring to the CPU. The only way you can harm a modern chip is with too much voltage. High temperatures won't do a thing.
  #22 (permalink)
Old October 10, 2009, 06:04 PM
while you guys go back and forth any chance you can tell me is anything looks wrong in the voltage?
  #23 (permalink)
Old October 10, 2009, 06:09 PM
gingerbee's Avatar
nothings to high i would not worry about it
  #24 (permalink)
Sushi Warrior's Avatar
You have a 920 sitting around? Load it up @ 1.45v and turn off your fans. If it turns itself off and still turns back on, you win.
  #25 (permalink)
Old October 10, 2009, 06:12 PM
Everything looks fine to me.
I don't have an i7, but the thermal protection mechanism for those CPUs is the same as the one used in the Core 2 line of CPUs. And I've actually run my Q9550 right up to the limit, although I wasn't able to get it to trigger the thermal shutdown since the throttling reduced the temperature too much. I have also read the Intel documentation relevant to their thermal protection features for both the Core 2 and Core i5/i7 product lines.
  #26 (permalink)
Old October 10, 2009, 06:20 PM
gingerbee's Avatar
yes it's true that c2d's can and will run with just ambient ( how good is it for them i don't know i go by my gut feelings on this cooler the better. JMO )
  #27 (permalink)
Old October 10, 2009, 06:27 PM
Yes, cooler is better, but you're basically just reducing the lifespan of the CPU from 20 years to 19 years. In the long run, the CPU will be obsolete long before it ever dies from being exposed to too much heat.
  #28 (permalink)
Old October 10, 2009, 06:41 PM
uhm ram timings are 6-7-6-18 at 1600 also incase it matters. and at 1.3 I can get it to around 3.4 after that I must raise it to go higher. I will wait till I do sum mods to my 800d before I go much further
  #29 (permalink)
Old October 10, 2009, 07:28 PM
somecanadianguy's Avatar
I was under the impression that most D0 chips need fairly low vcore.
Why would he need 1.3V for 3.4GHz, when my C0/C1 does 3.5GHz with only 1.2375V?
Maybe you should start an OC thread and get things sorted out.
  #30 (permalink)
Old October 10, 2009, 07:34 PM
kinda disappointed here because of that, I even payed the extra for a d0 stepping. I guess I just got a crappy chip then
not bad temps with 511's badatcards HardwareCanucks F@H Team 4 July 24, 2009 10:10 AM
DC - All that bad? JD Off Topic 16 December 24, 2008 08:27 AM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
Bad Ram?? Jarod_g29 RAM 9 February 26, 2008 11:33 AM
