<~----> Need i7 cooler Advice - Hardware Canucks
Old October 8, 2009, 09:01 PM
Default Need i7 cooler Advice
Hey, I'm new to HWC. I've always lurked here and read your reviews, just never thought to join.
I just received a shiny new i7 machine last week from NCIX. My parents didn't trust me enough to let me build my own, but NCIX did a great job. I was on a budget and I got an Arctic Cooling Freezer 7 Pro Rev 2. Everywhere I look tells me that this is a bad cooler and not to overclock with it. Only reason I bought it was to stay under a budget.
I'm currently running the i7 at 3.0 ghz with Turbo and HT off. I get up to 60 at load but games I play push it into the 50s. I tried 3.2 Ghz but the PC wouldnt boot. I used Gigabyte's Easytune software to overclock, so that may be the problem. I don't want to go higher or try manual overclocking until I get a better cooler. I've got more money now and I'm considering a couple options. Aiming for 4.0-4.2 Ghz under 100 bucks and something that'll fit onto my board and in my case.
Here's my rig at the moment.
CPU: Intel Core i7 920 D0 Stepping
Cooler: Arctic Cooling Freezer 7 Pro REV.2 Cooler
Motherboard:Gigabyte EX58-UD5
Memory: Corsair XMS3 CMX6GX3M3A1600C9 6GB DDR3 3X2GB DDR3-1600 CL 9-9-9-24
GPU: XFX Radeon HD 4890 XXX 1GB
Case: Coolermaster cm 690 mid Tower
PSU: Corsair Professional HX650W
HDD: Western Digital Caviar Blue SE16 640GB SATA2 7200RPM 16MB
Windows 7 RTM
My budget for a cooler is 100 dollars max.
Here's what I'm considering:
The Scythe Mugen 2 (Rave Reviews everywhere)
Cooler Master Hyper 212+
(canada computers salesman said it was good, read good reviews in some places)
Looks like it beats V8 and V10 in reviews
Corsair H50 (Trust Corsair, maybe they cool well too, someone said I should go for watercooling at 4 Ghz)
Prolimatech Megahalem (rave reviews)
I'd prefer something I can pick up instore at Filtech or Canada Computers or any other store in the GTA. Those are the only stores here in Toronto that had i7 coolers in stock.
Your input is appreciated.
Old October 8, 2009, 10:23 PM
megalems hands down
i just got one commin in this week for 50$ @ncix
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old October 9, 2009, 07:23 AM
Arinoth's Avatar
I'm happy with my CM Hyper 212, sure doesn't perform as good as the expensive guys, but it does the job quite well and with proper air flow in your case you can keep your temps down.
Example:
I am in a dorm room, using CM 690 Case, when i had stock case fans and HSF temps in room could get up to 30C and CPU temp would get to 80-82C. Now with proper air flow and case fans galore i can at 30C keep my temps down to 77C max at same ambient temp. I've also heard this HSF really shines in cooler ambient temps but haven't gotten to test it much below 20C
Old October 9, 2009, 07:44 AM
Soultribunal's Avatar
Zalman CNPS 10X Extreme.
My thoughts at least. Welcome to the forums.
ST
Old October 9, 2009, 08:03 AM
stoanee's Avatar
Megahalem, you just missed the sale... TRUE is good also.
heatware
Old October 9, 2009, 10:23 AM
LionRed's Avatar
Shiny...since your folks bought you this computer. I wouldn't push the OC too much, cause if you cook something. You will have a lot of explaining to do.
A few things might happen -
1.) They might never want to buy anything from NCIX again.
2.) They may not replace your cooked computer.
3.) If they do not replace the broken part/parts...where will you be for a computer then (probably can RMA stuff out, but mailing things cost money).
You got a sweet computer there....
Choo Choo bitches, progress coming through.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy
Old October 9, 2009, 11:03 AM
Yeah but thats only gonna happen if you really start playing around with the voltages and don't know what your doing.
The Heat side of it so long as you don't exceed the limits your fine.
My thoughts at least,
ST
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 01:52 AM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
seeking advice on new CPU cooler Polygon Air Cooling 5 August 20, 2009 02:58 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
Another peculiar GPU cooler from Cooler Master: CoolViva Pro Review by X-Bit Babrbarossa Reviews & Articles from the Web 7 March 19, 2007 04:19 AM
