Old October 6, 2009, 10:51 AM
Extreme_kid's Avatar
Homedepot sells 22 gauge steel sheets , anywhere I can find thicker sheets of metal ?
E8400 @ Stock / GA-EP45-UD3P / OCZ BLade 8GB 1066 / ATI 4850X2 @ 700-1300 / WD Caviar Black 2x raid 0 / CM 850W / HAF 932 + 7 1900rpm fans / True Black ( Lapped - Bolt-tru - Washer - Push,Pull setup )
Old October 6, 2009, 11:04 AM
MpG's Avatar
MpG MpG is offline
If you're determined to go that route, you'll need something much thicker. Most heatsink backing plates are ribbed for more rigidity - the ones that are flat are often using anywhere from 8-14 gauge metal. Your best bet is to find a metal-mart of some sort and see if they sell smaller pieces. You'll also need some sort of tool for cutting the stuff - a hacksaw will take a long time. Also make sure it won't short out the back of the motherboard - a few layers of rubber/neoprene/felt cloth will make sure of that.
Best method for 4870X2 fan speed changes cwestwell Guides & How-to's 19 January 16, 2009 09:20 AM
your thermal paste method CTA CPU's and Motherboards 25 December 16, 2008 02:12 AM
Mobo mounting Formaldehyde Troubleshooting 2 December 10, 2008 08:50 PM
Need help mounting a fan Kentalish Air Cooling 5 July 20, 2008 03:31 AM
Safest BIOS Flash Method? mattydies CPU's and Motherboards 11 May 20, 2008 06:31 PM
