<~----> Prolimatec - Hardware Canucks
Old October 2, 2009, 07:10 PM
martin_metal_88's Avatar
Default Prolimatec
Hey guys, juste receive and install my new Megahalem and...It's a charm. Easy to install perform way better then my H50 or my vendetta 2. I would recommend it any time this week because 50$ at NCIX! go for it guys!!!
Ask for more.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old October 2, 2009, 07:30 PM
stoanee's Avatar
Very good heatsink, awesome mounting system!
heatware
Old October 2, 2009, 07:38 PM
i put it in the cart still thinkin about it lol
i have a true on my e8600 dont know if its gonna be much better
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old October 2, 2009, 08:07 PM
well...yeah:) It score 2 to 3 degree under on my Q9550. I will try push pull soon. It sould be even better. Can i get 22 idle at 3.6? maybe:)
Ask for more.
Ask for more
Martin_metal_88
Old October 2, 2009, 09:03 PM
Ask for more.
can you try 4.0+?
i get 61-65 load on coolmaster 212 @ 4.25 with q9650
my true loads @ 55c @ 4.5 with e8600
i think i gonna need lots of thermal paste to do tests if i get it
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old October 2, 2009, 10:05 PM
stoanee's Avatar
Typically the big coolers work the best when they are cooling a really hot chip like an overclocked Q6600 or I7. You may not see as good a result on a cooler chip, but you should be able to run quieter fans and still have good cooling.
heatware
Old October 2, 2009, 11:13 PM
i think i'm gonna get it
wife thinks i deserve a 4800ghz e8600
now i just wishe they had somethin else i can buy since shippin will be about the same lol
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old October 3, 2009, 07:47 AM
Originally Posted by zsamz_ View Post
can you try 4.0+?
I will try it tonight if I have time to do it. Will post some some result;). I have been able to do it easy with a H50 so I think the Megahalems will do it just fine.
Ask for more.
Ask for more
Martin_metal_88
Old October 7, 2009, 11:09 PM
For those that had a TRUE, how did the megahalems perform compared to it using a higher static pressure 38mm fan? I have a TRUE Black Rev. C and I'm still deciding if I should give the Megahalems a try. My TRUE Rev. C doesnt need to be lapped or pressure modded, it's something they fixed in the new revision.
Old October 8, 2009, 06:03 AM
gingerbee's Avatar
can you try 4.0+?
Maybe if your ambient is 22c or lower
