Old September 19, 2009, 08:27 PM
Caldezar's Avatar
Default Advice on a Xigmatek 'Red Scorpion'
So I'm looking to attempt a core unlock, and some O/C'ing on my X2 550BE. But before I go at this, I am going to upgrade my stock cooler. The one I'm looking at right now is the Xigmatek Red Scorpion. I've read nothing but good reviews on the cooler, except for the people complaining about the 'push pin' mounting system.
So I'm just wondering if anyone has any experience with this cooler? It seems to be very decent performance, and price is key. If anyone knows of this being a bad cooler, let me know. I'm also open to suggestions, but remember I'm looking to keep the price reasonable. I'm not looking to squeeze every last drop out of the system, just O/C a bit and stay in the safe zone.
Old September 19, 2009, 08:38 PM
gingerbee's Avatar
I think it's just a xiggy with a decent fan
Old September 19, 2009, 11:05 PM
The Red Scorpion is just the S1283 with a different fan. I have an S1283 and it does a fine job of cooling my Q9550. You'll be fine with that cooler and your CPU (although you may want to go with the standard HDT-S1283 instead if it comes out cheaper).
Old September 19, 2009, 11:21 PM
MacJunky's Avatar
I have a regular HDT-S1283 as well and no complaints.
Old September 19, 2009, 11:37 PM
Get this instead: Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA775 LGA1156 120MM - DirectCanada
It comes with 4 fan clips if you want to do push/pull.
Old September 20, 2009, 12:23 AM
Caldezar's Avatar
^^ Do run one of those Johnny? Any feedback on the general fan volume on it?
Old September 20, 2009, 12:40 AM
Perineum's Avatar
I just picked one of those up, it's mounting style is brilliant, as I mentioned to you.... I don't know about it's volume yet as that machine will just turn on tomorrow for the first time.
Old September 20, 2009, 01:46 AM
Caldezar's Avatar
Let me know Perineum. Volume's fairly important, but the price is right...
Old September 20, 2009, 07:18 AM
I ordered 2x but of course I haven't received them yet. I plan on putting couple of Noctua NF-P12s (which I already have).
Xigmatek Backplates JD Air Cooling 7 August 6, 2009 08:18 PM
Red really sucks Mark O/S's, Drivers & General Software 13 March 18, 2009 03:21 PM
Xigmatek S1283 Red Scorpion CPU Cooler Review Hardware Canucks Air Cooling 0 May 8, 2008 10:23 AM
Xigmatek Red Scorpion S1283 HDT CPU Cooler Das Capitolin Member Reviews 0 April 22, 2008 11:31 PM
3 red lights. belgolas Off Topic 14 February 21, 2008 05:40 PM
