Old September 17, 2009, 07:05 PM
Default Stock CPU cooler?
Hi,
I'm purchasing a Intel Q9550 2.83Ghz CPU. I'm wondering if the stock CPU fan/heatsink is gonna be good enough.
I do gaming but not planing to overclock it.
By how much degrees Celsius does a decent aftermarket cooler run vs stock ones?
Also, is the stock fan gonna be a lot more noisy?
thanks!
Old September 17, 2009, 07:08 PM
Originally Posted by chang2 View Post
Hi,
thanks!
stock is fine as the quads are thicker than the duals and will be fine.
Old September 17, 2009, 07:38 PM
thanks
Old September 18, 2009, 04:44 AM
Apathetik's Avatar
NCIX.com - Buy Zalman CNPS10X Extreme CPU Cooler 120MM PWM LED Low Noise Fan LGA1156 1366 775 AM3 754 939 940 - CNPS10X Extreme In Canada.
^ win
ASUS VE278Q 27" LED / DAS Professional Model S Cherry MX Blue Mechanical / Logitech G500 - QcK Mass / Corsair Veng 2000 / Windows 7 Ultimate 64bit
Old September 18, 2009, 06:14 AM
steers's Avatar
NCIX.com - Buy Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA775 LGA1156 120MM - RR-B10-212P-GP In Canada.
^ win
Balthasar - Loop: EK Multi 150 > MCP655 w/X-Top2 > Feser X-Changer 360 w/3x Panaflo 68cfm (push) > Heatkiller 3.0 > EK-FC275 > EK-FB Classified
Caspar - 2x Xeon E5504 | SuperMicro X8DAi | 12GB DDR3 | Radeon HD4850 | CM ATCS840
Melchior - Rev. A MacBook Pro | 2.0GHz Core Duo | 2GB DDR2 | Radeon X1600
Bob - Core i3 530 | Gigabyte H55N-USB3 | 4GB DDR3 | Corsair H50 w/ TFC Triebwerk | Silverstone SG06
Old September 18, 2009, 06:58 AM
Arinoth's Avatar
You should be fine with stock if you are not over clocking
Old September 18, 2009, 08:15 AM
martin_metal_88's Avatar
Price??? WTF 91 box
+1 Hyper 212 or vendetta 2
But you will be fine with stock cooler if no plan to OC.
Ask for more.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Removing stock cooler for OCZ Vendetta 2 ricknash61 Air Cooling 5 September 7, 2008 11:23 AM
stock cooler problem v0maru Air Cooling 2 April 13, 2008 03:21 PM
WTB: 2900 XT stock cooler alexgheseger Buy/Sell & Trade 6 January 29, 2008 03:12 PM
8800 GT gets a new stock cooler Babrbarossa Press Releases & Tech News 6 December 6, 2007 08:42 AM
Amd cpu stock... omgwtf CPU's and Motherboards 7 April 12, 2007 06:07 PM
