Old September 8, 2009, 06:14 PM
Unknownm's Avatar
Default Simple way to cool my chipset!
. This small pathetic heatsink was super hot that when I touched it it actually hurt.:rtfm:. Got some super glue with a extra AMD fan, New cooler
Old September 8, 2009, 06:24 PM
Your not running your memory in dual channel.
Old September 8, 2009, 06:32 PM
ITaoI's Avatar
I have a Antec spot cool on mine cools it nicely. Have you thought about replacing the TIM with some AS5 or other TIM it really helps it dropped mine by like 10c+
CPU-Z AMD Phenom I x4 9950 3.2/2.3nb
CPU-Z AMD Phenom II x2 550be 3.8/2.6nb
CPU-Z AMD Phenom II x3 710 3.6/2.5nb
CPU-Z Intel i7 2600k 4.6
HEATWARE:Tao
JD JD is offline
Some AM2 systems used side-by-side slots for dual-channel. Could be mistaken though, but he has them in the same colours.
Old September 8, 2009, 06:33 PM
ooooh never noticed.
I retract my previous statement.
Old September 8, 2009, 06:41 PM
Unknownm's Avatar
yeah some am2 MB do run Dual channel with the same color slots.
Old September 8, 2009, 07:04 PM
TopDogZero's Avatar
Be careful with super glue, I've noticed that it will degrade over time especially in hot environments like in a PC, it gets brittle and eventually lets go. Wouldn't want that fan to let go and decapitate some unlucky component .
Old September 8, 2009, 07:16 PM
Unknownm's Avatar
Yeah well this is only until I have another job and get NEW CPU/Chipset/GPU heatsinks
Old September 8, 2009, 07:20 PM
Jake_HT's Avatar
Very techy futuristic cooling method
http://jakeht.deviantart.com/
Old September 8, 2009, 08:50 PM
TopDogZero's Avatar
Should not be a problem then, it takes months for it to degrade.
Q9550 to stock cool or custom cool? lKashl CPU's and Motherboards 11 June 11, 2009 04:33 AM
Hopefully A Simple one Soultribunal Troubleshooting 4 March 27, 2009 07:35 PM
Simple question. clone63 CPU's and Motherboards 3 March 26, 2009 07:48 PM
Simple Question Scutum_Deus CPU's and Motherboards 8 September 22, 2008 06:31 AM
Who is using nTunes and is there something better thats simple? Canadianguy Video Cards 4 December 3, 2007 08:14 AM
