Old September 8, 2009, 09:15 PM
jcmaz's Avatar
How bout that Gorilla Stuff?
-Plato
Old September 9, 2009, 06:38 AM
TopDogZero's Avatar
Don't know, have used it only once and not in high temp.
Old September 9, 2009, 11:40 AM
Arinoth's Avatar
Originally Posted by TopDogZero View Post
Be careful with super glue, I've noticed that it will degrade over time especially in hot environments like in a PC, it gets brittle and eventually lets go. Wouldn't want that fan to let go and decapitate some unlucky component .
That's why i'd recommend using a rubber band as safety around the two holding them.
Old September 9, 2009, 01:47 PM
steers's Avatar
You could probably finagle a solution using zip ties as well.
Balthasar - Loop: EK Multi 150 > MCP655 w/X-Top2 > Feser X-Changer 360 w/3x Panaflo 68cfm (push) > Heatkiller 3.0 > EK-FC275 > EK-FB Classified
Caspar - 2x Xeon E5504 | SuperMicro X8DAi | 12GB DDR3 | Radeon HD4850 | CM ATCS840
Melchior - Rev. A MacBook Pro | 2.0GHz Core Duo | 2GB DDR2 | Radeon X1600
Bob - Core i3 530 | Gigabyte H55N-USB3 | 4GB DDR3 | Corsair H50 w/ TFC Triebwerk | Silverstone SG06
Old September 9, 2009, 02:41 PM
bissa's Avatar
ya, I have a rubber band holding the fans on my GPU heatsink, however I don't think there is anything he can use an elastic band on. using a couple zapstraps through the screw holes would probably be a good idea.
Strong like hummingbird, swift like oak.
Q9550 to stock cool or custom cool? lKashl CPU's and Motherboards 11 June 11, 2009 04:33 AM
Hopefully A Simple one Soultribunal Troubleshooting 4 March 27, 2009 07:35 PM
Simple question. clone63 CPU's and Motherboards 3 March 26, 2009 07:48 PM
Simple Question Scutum_Deus CPU's and Motherboards 8 September 22, 2008 06:31 AM
Who is using nTunes and is there something better thats simple? Canadianguy Video Cards 4 December 3, 2007 07:14 AM
