-   Air Cooling (https://www.hardwarecanucks.com/forum/air-cooling/)
-   -   Could you guys recommend a CPU heatsink? (https://www.hardwarecanucks.com/forum/air-cooling/22328-could-you-guys-recommend-cpu-heatsink.html)
Airshehan August 26, 2009 11:08 AM
Hey Guys,
I have a Q9300 processor with the stock cooler on it. I want to overclock my processor to around 3GHz. My main issue is that I don't want to remove the motherboard from my case to install the new heatsink. I have a Dell XPS 630i and I bet Dell made removing the motherboard hard! Could you guys recommend a good heatsink for me? I was originally looking at the TRUE and the Vendetta 2. I want the best temps possible! BTW, how long do you think my processor would last at that speed with good cooling?
Thanks Guys!:thumb:
cdn_Madrach August 26, 2009 11:21 AM
Well if you are looking for good temps those coolers will do a good job but I highly recommend using a backplate with either one. Which will require mobo removal but ensure those stupid little pushpins don't let go and your hsf falls off. Not sure about the true having pushpins but the vendetta 2 does. Also be sure whatever hsf you use will fit in your case.
JD August 26, 2009 11:24 AM
Cooler Master Hyper 212 Plus. Though you'll have to remove the motherboard.
If you really can't, then the Vendetta 2 is your only choice. The TRUE needs motherboard removal too.
If it looks like this:
http://www.driverheaven.net/reviewim...re/inside3.jpg
Then the motherboard should be easy enough to remove. Looks like the stock heatsink has a backplate as well, which might need to be removed.
Arinoth August 26, 2009 11:35 AM
Either are good choices, i've been happy with the hyper 212 for its price point and how well it cools.
Off topic: jdrom17 i love how it has the airflow direction sticker on it.
shayan288 August 26, 2009 11:47 AM
My Vendetta 2 with Thermalright bolt thru kit, gets me pretty good temps, I would definately recommend that. It can also be had for 20 bucks on sale, like last week.
martin_metal_88 August 26, 2009 12:55 PM
Vendetta 2 have done miracle for me. The best thing I can say to you is look at these chart ( HWC cpu cooler chart )
http://www.hardwarecanucks.com/forum...-review-9.html
Look at all the 10 first cooler I think 10 is a fait number, ok the 9 first ebcause the 10 is Coolermaster V10 code name piece of shit, and take the one you prefer between all these according to price and to look in your build. If you can't remove mobo then look into vendetta 2 it's your only option. Don't forget to see for Backplate if not included with cooler.
Ask for more.
Airshehan August 26, 2009 01:22 PM
Thanks for all of the info guys! I think I might just go with the Vendetta 2! How easy is it to install the heatsink? And if I do choose to go with the Vendetta 2, will I have to remove the backplate of the stock cooler?
Thanks guys!
Kilauea August 26, 2009 01:27 PM
Vendetta II, Coolermaster 212 or the Xigmatek HDT-S1283... But make sure ur Dell mobo allows you to overclock too.
Airshehan August 26, 2009 01:31 PM
Yes, my motherboard does allow me to overclock! It is a Nvidia Nforce 650i SLI! So, to install those heatsinks, would I have to remove the backplate of the stock cooler?
Airshehan August 26, 2009 01:33 PM
BTW, which heatsink is the best out of the three Kilauea listed?
