View Poll Results: Which Fan Controller?
Scythe Kaze Master Ace 3 14.29%
NZXT Sentry LX 2 9.52%
Zalman ZM-MFC3 8 38.10%
Other 8 38.10%
Voters: 21. You may not vote on this poll
Old August 19, 2009, 11:28 AM
Default Which Fan Controller?
I'm thinking about getting a fan controller unit. I've tried software based controllers Speedfan which is hit & miss at best (as well as a bit of a learning curve) and the reasonably okay Asus Q-Fan which my mobo supports. But I'm thinking a controller device would be better for easy access and case bling.
I think I've narrowed it down to three models. Not sure if the knobbed ones will fit behind the door of the Raven case but if it doesn't I'll use it in my Antec Nine Hundred.
Scythe
NZXT
Zalman
Thoughts? Suggestions?
System Spec Peripherals: Corsair H70 cpu cooler (w/ 2 120mm Scythe Gentle Typhoon 1850rpm fans) | Zalman MFC3 fan controller | Gigabyte Aivia Osmium kb | Steelseries Sensei mouse | Logitech Z-2300 2.1 speakers | SteelSeries SX mouse surface
For the real serious stuff: 2.53GHz Mac Mini | 4GB DDR3 1066 RAM | 320GB HDD | Samsung P2250 (x2) | Apple Magic Mouse | Apple Magic Trackpad | Apple Wireless KB | Drobo FS 6.5TB
Laptops: Dell XPS M1530 | Asus G74SX-DH71
Surface Pro 128GB
Old August 19, 2009, 12:14 PM
Haven't tried any of them but I like the looks of the NZXT
Current Rig: C2D E6400 @ 3.0GHz, Vendetta II, BFG 8800 GT, OCZ PC6400 8GB, HX520W, 2x WD 500GB HD, Segate 160GB, WD 200 GB HD, Lancool PC-K62, Windows 7 64 bit, Snow Leopard (on the way)
EVGA 680i SLI Motherboard $80 + Qualitas 73GB 10k SCSI $30
Old August 19, 2009, 12:48 PM
CMetaphor's Avatar
Quadfather
Ive tried the NXZT and the viewing angle is awful. So unless you're far away an facing or your system sits up high in front of your face, its not very useful.
The Kaze master is alright for a cheap solution, but if you can afford it the power monitoring and nicer look of the Zalman is what i would go for.
Old August 19, 2009, 08:53 PM
I'm partial to the Zalman MFC-1 Plus (not on list). Yes it's an oldie compared to others but still great. Combination of simple functionality, nice simple design, no fancy lcds (unless you like em), just dials + controls 6 fans.
Old August 19, 2009, 09:36 PM
1Tanker's Avatar
I agree 100% with morphy.
Old August 19, 2009, 09:41 PM
This:
Lamptron FC-3- 30 Watts Per Channel 4 Channel CNC Milled Fan Controller - Black Products Model: FC-3-BK [FC-3-BK] : Performance-PCs.com, ... sleeve it and they will come
Try and find it in canada.. otherwise order it.
You'll be very happy.
Old August 20, 2009, 02:58 AM
I had no idea Zalman has a newer model, i've got the MFC-2, i like it other than the restrictive viewing angles, this looks to be much improved.
Old August 20, 2009, 07:07 AM
curtispan's Avatar
Have not tried any of the ones you listed, but I recently got a Sunbeam Rheobus, and it's great. I run 2 Yate Loons for intake on 1 channel, 1 Yate Loon for exhaust on another channel, a 200mm Big Boy on a third, and my PSU fan on the 4th. (Did a little fan mod to reduce noise )
My only gripe is the friggin' bright LEDs. Going to rip them out and cover them with a little paint. Should fix the problem, but hey, for $13 PM'd, you can't go wrong.
Old August 20, 2009, 09:41 AM
jumran's Avatar
If you want NZXT controller, this one would be a cheaper option but it is not available in Canada yet.
http://www.newegg.com/Product/Produc...82E16811992005
Old August 20, 2009, 10:16 AM
^That looks less gaudy than the Sentry. I might watch for that one. Thanks for the head's up.
I am also leaning towards the MFC3. :)
Surface Pro 128GB
zalmaan 6 fan, fan controller quikgp Peripherals 4 May 29, 2009 09:32 PM
[WTB] fan controller kyle_L Buy/Sell & Trade 0 March 11, 2009 09:20 PM
fan controller help kyle_L Air Cooling 4 March 5, 2009 10:51 PM
fan controller help Computergeek Troubleshooting 19 July 25, 2008 02:28 PM
Fan Controller Computergeek Air Cooling 5 July 9, 2008 06:16 PM
