View Poll Results: Which Fan Controller?
Scythe Kaze Master Ace 3 14.29%
NZXT Sentry LX 2 9.52%
Zalman ZM-MFC3 8 38.10%
Other 8 38.10%
Voters: 21. You may not vote on this poll
  #21 (permalink)
Old August 23, 2009, 08:24 PM
Originally Posted by aviduser View Post
I'd try and put it on the side of the cpu if possible.
Yep. That's what I'm thinking. I did see some photos on-line of someone actually sticking the probe on top of the chip but he/she also did not think it was really a good idea. Not sure what the results were but I'm not going to take a chance.
System Spec Peripherals: Corsair H70 cpu cooler (w/ 2 120mm Scythe Gentle Typhoon 1850rpm fans) | Zalman MFC3 fan controller | Gigabyte Aivia Osmium kb | Steelseries Sensei mouse | Logitech Z-2300 2.1 speakers | SteelSeries SX mouse surface
For the real serious stuff: 2.53GHz Mac Mini | 4GB DDR3 1066 RAM | 320GB HDD | Samsung P2250 (x2) | Apple Magic Mouse | Apple Magic Trackpad | Apple Wireless KB | Drobo FS 6.5TB
Laptops: Dell XPS M1530 | Asus G74SX-DH71
Surface Pro 128GB
  #22 (permalink)
Old August 23, 2009, 08:36 PM
Sushi Warrior's Avatar
You're either going to ruin the contact of the HS to CPU or crush the sensor. It has been done where you mill a channel into the middle of the IHS.
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
  #23 (permalink)
Old August 24, 2009, 10:54 AM
Originally Posted by Signal2Noise View Post
I ended up buying the MFC3 today. Hopefully will get set up today or very soon when I get a chance. Just need to find good tutorials on placing the thermal sensors, especially the CPU. I'm leery of sandwiching a sensor b/w the CPU and fan cooler.
Personally the only probe i put on the CPU was on the back of the motherboard, also placed one on a RAM heat spreader one on a hard drive and the last is running along the GPU plug reading the ambient air near the center of the case.
I suppose you could put them on the actual CPU and or GPU or memory IC but that's also likely to hinder your cooling performance, not to mention a lot more work.
  #24 (permalink)
Old August 24, 2009, 11:38 AM
I appreciate the tips, traitoR. I think I'll be wiring it all tonight. Placing the cpu probe on the other side of the mobo is a great idea. I imagine the temp difference would not be much.
I plan to place probes:
-CPU
-GPU
-RAM
-Case exhaust or center
Surface Pro 128GB
  #25 (permalink)
Old August 24, 2009, 11:34 PM
So I managed to get it all set up tonight. Things are looking good but I do have a couple of questions that perhaps can be answered by an MFC2 or MFC3 owner.
1. The CNPS9700 CPU fan is 4-pin. It seems the C3 cable cannot be used with this fan. Since the CNPS9700 is PWM (I think) should I just be using the provded 4-pin PWM cable directly from fan to MFC3? Which means the fan will not be plugged into the mobo. Or do I use the C3 cable from mobo 4-pin at the same time as using the PWM?
2. Can the thermal sensor probes be placed/taped directly to the surface of the mobo? Will the contacts covering solder points cause a short or something? I want to monitor the temp of the CPU as traitoR describes by placing the probe on the back of the mobo directly behind the CPU mount. But there are a lot of solder points there. Same with GPU.
Sorry if these are dumb questions but I'm a noob to this sort of thing. I also sent an email to Zalman but figure folk here may already have the answers.
Cheers!
Surface Pro 128GB
zalmaan 6 fan, fan controller quikgp Peripherals 4 May 29, 2009 09:32 PM
[WTB] fan controller kyle_L Buy/Sell & Trade 0 March 11, 2009 09:20 PM
fan controller help kyle_L Air Cooling 4 March 5, 2009 10:51 PM
fan controller help Computergeek Troubleshooting 19 July 25, 2008 02:28 PM
Fan Controller Computergeek Air Cooling 5 July 9, 2008 06:16 PM
