View Poll Results: Which Fan Controller?
Scythe Kaze Master Ace 3 14.29%
NZXT Sentry LX 2 9.52%
Zalman ZM-MFC3 8 38.10%
Other 8 38.10%
Voters: 21. You may not vote on this poll
Old August 20, 2009, 11:42 AM
martin_metal_88's Avatar
Sunbeam Rheobus is also a great one and they are powerfull. Also take a look at the little bro the standard rheobus.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old August 20, 2009, 11:59 AM
^I thought about the Rhoebus Extreme but am not sure if the knobs will interfere with the drivebay door of the Raven. Will look into it. Thanks.
System Spec Peripherals: Corsair H70 cpu cooler (w/ 2 120mm Scythe Gentle Typhoon 1850rpm fans) | Zalman MFC3 fan controller | Gigabyte Aivia Osmium kb | Steelseries Sensei mouse | Logitech Z-2300 2.1 speakers | SteelSeries SX mouse surface
For the real serious stuff: 2.53GHz Mac Mini | 4GB DDR3 1066 RAM | 320GB HDD | Samsung P2250 (x2) | Apple Magic Mouse | Apple Magic Trackpad | Apple Wireless KB | Drobo FS 6.5TB
Laptops: Dell XPS M1530 | Asus G74SX-DH71
Surface Pro 128GB
Old August 20, 2009, 12:29 PM
TimTheEnchanter's Avatar
+1 if it fits your case. Powerful, neat, cheap, efficient.
The LEDS are way too bright, but can be fixed easily. If you like lights inside your case, your can bend em back into the case and it makes it all shiny
Old August 20, 2009, 02:44 PM
I just open mine and cut the led because I hate them. Everything can be unmount fast and cut in a heartbeat.
Ask for more.
Ask for more
Martin_metal_88
Old August 20, 2009, 02:45 PM
don't have to cut the leds just pull em out.
2nd Zalman fan controllers are imho garbage as they add a ton of extra wiring to your case that really isn't needed.
Old August 20, 2009, 05:13 PM
Not sure what you are talking about ? It's not rocket science to install a fan controller and if you are moderately inclined relatively easy to maintain a descent level of organization.
Here is my last build, contains a Zalman MFC-2 as well as a card reader all wired in their entirety, not to mention in a smaller Antec 300 case.
Old August 20, 2009, 05:33 PM
Nice & clean, traitoR. Can you come over and cable my case? :)
How do you like the MFC2?
Surface Pro 128GB
Old August 20, 2009, 05:53 PM
It's not that hard to cable a clean case, a little forward looking thought, some mockup as well as taking your time and putting in an effort to conceal things is all it takes.
Personally i like the Zalman controller, i only run 3 fans off it, all intake, the exhaust fans are tri-cools locked at med, it's easy enough to adjust fan speed, the view angles are the biggest complaint you will see, although the display has dimmed since i got it and has become easier to discern, it was quite bright initially.
I admit the cool factor played a part in my purchase I like pretty lights and the power monitoring ... Still i've never had a problem with the fan portion or temp probes.
  #19 (permalink)
Old August 23, 2009, 12:52 PM
I ended up buying the MFC3 today. Hopefully will get set up today or very soon when I get a chance. Just need to find good tutorials on placing the thermal sensors, especially the CPU. I'm leery of sandwiching a sensor b/w the CPU and fan cooler.
Surface Pro 128GB
  #20 (permalink)
Old August 23, 2009, 06:08 PM
aviduser's Avatar
And you should be, very bad idea IMO.
I'd try and put it on the side of the cpu if possible.
HAF-Full
-Phenom II 940 @ 3.8 ghz
- Sapphire 5870 890/1220
- 4 ghz g.skill
- Corsair tx850w
zalmaan 6 fan, fan controller quikgp Peripherals 4 May 29, 2009 09:32 PM
[WTB] fan controller kyle_L Buy/Sell & Trade 0 March 11, 2009 09:20 PM
fan controller help kyle_L Air Cooling 4 March 5, 2009 10:51 PM
fan controller help Computergeek Troubleshooting 19 July 25, 2008 02:28 PM
Fan Controller Computergeek Air Cooling 5 July 9, 2008 06:16 PM
