-   Air Cooling (https://www.hardwarecanucks.com/forum/air-cooling/)
-   -   Side 80mm Fan In vs. Out (https://www.hardwarecanucks.com/forum/air-cooling/21814-side-80mm-fan-vs-out.html)
Dadi_oh August 11, 2009 03:15 PM
1 Attachment(s)
I have a smaller case, an Ultra Gladiator with a 120mm inlet fan and a 120mm exhaust fan. The power supply has a 135mm temp controlled exhaust fan. I also have a pair of 4870 video cards with the original heatsinks (exhaust outside of the case) running at 40% fan speed.
The case also has a side port but due to the height of my OCZ Vendetta 2 heatsink I can not put a fan on it so it is just a grill. However, there is a side vent down near the video cards so I decided to throw a 80mm fan on there.
Here is where it gets interesting. I was thinking about whether to run this fan as an inlet or an exhaust. So I ran some experiments and was rather surprised by the results.
It is fairly warm in the room, about 26-28C. I am using speedfan to measure my system temp (I assume the motherboard temp somewhere on my P5Q-PRO) and the core temps.
First I ran the system with the side 80mm fan on exhaust with Prime 95 small FFT's to warm things up and measured a system temp of 44C.
I then ran 3DMark06 looping through all the tests to get the video cards warm and measured 50C system temp.
I switched the side 80mm fan over to inlet and ran the same experiments and got just 36C with Prime95 and 43C with 3Dmark06 looping.
So to summarize:
Test 80mm exhaust 80mm inlet
P95 small FFT 44C 36C
3DMark06 loop 50C 43C
My theory is that is I put the 80mm on exhaust I end up with exhaust fans of 120mm (rear) + 135mm (power) + 80mm (side) vs. only a 120mm inlet (front). I think this sets up a negative pressure in the case and the exhaust feature of the 4870's can't work properly against that pressure.
If I switch it to inlet then I have a 120mm (back) + 135mm (power) vs. 120mm (front) + 80mm (side).
Just a piece of info for anyone in similar circumstances.
Sushi Warrior August 11, 2009 03:27 PM
I have the same case and found the same thing. The front HDD bays basically make the front 120mm useless....
mo' power August 11, 2009 05:55 PM
I would use it as an intake to provide a bit more fresh air circulation for your video cards.
Dadi_oh August 11, 2009 06:53 PM
Yup. That is the way this setup works best. Video cards are hitting about 60C on the cores during gaming which is pretty reasonable.
