-   Air Cooling (https://www.hardwarecanucks.com/forum/air-cooling/)
-   -   New fan on a Vendetta 2? (https://www.hardwarecanucks.com/forum/air-cooling/21785-new-fan-vendetta-2-a.html)
shayan288 August 10, 2009 08:25 PM
Hi all,
I decided I wanted to put another fan on my OCZ Vendetta 2 CPU cooler (currently using stock fan) so I can get a bit better temps and a bit less noise.
Would there be a difference with noise and temps If i got one of these two?
NCIX.com - Buy Yate Loon D12SL-12 120MM RED/BLACK Fan 1350RPM 47CFM 28DB 3/4PIN Sleeve Bearing OEM Sleeved Retail - D12SL-12-RED/BLACK In Canada.
NCIX.com - Buy Noctua NF-P12-1300 120MM Ultra Quiet Cooling Fan 1100-1300RPM 63-92M3/H 12.6-19.8DBA Molex - NF-P12-1300 In Canada.
Thanks in advance.
s288:thumb:
Kilauea August 10, 2009 08:28 PM
I don't know but make sure to post your results when you do, I am quite interested... That's also a tag cuz I want to know too.
enaberif August 10, 2009 08:38 PM
Originally Posted by shayan288 (Post 238388)
Hi all,
Thanks in advance.
s288:thumb:
You can really only run 1 fan on that HSF without getting into some odd mounting setup.
With that said grab the Yate and you'll be plenty happy.
Sushi Warrior August 10, 2009 08:42 PM
The Gelid Silent 12 fans are also dec. But Yates win at that price.
Dar_ell August 10, 2009 09:30 PM
Yea, im really interested how your going to add two fans on the vendetta.
shayan288 August 10, 2009 09:59 PM
lol oh lawd. i think you guys misread me haha. I meant I wanted to REPLACE the stock lol. And I was reading that a yate and the noctua actually doesnt cool better than the stock fan... is that true?
Dar_ell August 10, 2009 11:04 PM
No clue if thats true but if your going to replace it with a S-flex don't, didn't do anything different for me. Makes me want to pick up a hyper 212, but CC only has the old version..
enaberif August 10, 2009 11:08 PM
Both the Yate and Noctua will have a higher static pressure than the stock one which should help.
Altho it really comes down to how much your pushing your cpu or not.
shayan288 August 10, 2009 11:37 PM
So I will get lower temps? Like now I am getting 36C average on my q9550 at 3.8. Would a Noctua bring it down to say 32C average?
enaberif August 10, 2009 11:40 PM
Idle temps really mean nothing its the temps your cpu hits under load that really matter.
Will a Yate/Noctua make a big change its hard to say as there are lots of things to factor in.
Generally speaking Yate/Noctua SHOULD perform better then general run of the stock HSF fans.
