Old August 7, 2009, 06:50 PM
Sushi Warrior's Avatar
I got an extra 120mm floating around, it's the stock fan from the NZXT whisper. Not silent but not too loud either, I'd send it to you for free (plus shipping I guess... depends on location). Just an offer, I know it isn't anything special.
Old August 7, 2009, 09:17 PM
where are u located exactly
if you're willing to goto (warden and 7) near toronto
maybe a S-flex f (wires braided - fail attempt so wires dont clip into my psu)?
edit-if i can find it
Intel Core 2 Duo e8400 @ 3.8GHz
Mushkin Ascent 1x2gb
Asus P5N-D
BFG Geforce 8800GT OC SLI (folding issues...)
WD 500GB
NZXT Apollo
OCZ Vendetta 2 w/ Bolt-thru kit +Scythe S-Flex F
Syncmaster T220, Razer Deathadder, Lycosa Mirror Edition, X-240 speakers
Old August 8, 2009, 12:41 PM
somecanadianguy's Avatar
I'm in the Cambridge/Kitchener area.
I'd like to get some feedback on a few fans.
Would like a couple of these maybe if I can afford them..
NCIX.com - Buy Scythe S-FLEX SFF21G 120MM Cooling Fan 1900RPM 35.0DBA 75CFM FDB 3/4PIN - SFF21G In Canada.
Maybe these...
NCIX.com - Buy Yate Loon D12SM-12C 120MMX20MM Cooling Fan 1800RPM 62CFM 29DB 3PIN & 4PIN Sleeve Bearing OEM - D12SM-12C In Canada.
These if I can't afford the S-Flex or YL's...
NCIX.com - Buy Scythe Ultra Kaze 120MM High Static Pressure Silent Fan 38MM 2000RPM 87.6CFM 32.9DBA - DFS123812L-2000 In Canada.
How are those choices?
Outta my price range right now, but soon I hope to afford some.
What about these?...
NCIX.com - Buy Scythe Gentle Typhoon 120MM Case Fan 1850RPM 28DB 58.3CFM - D1225C12B5AP-15 In Canada.
They look pretty cool, but would they be good on a TRUE?
Are they at all worth the money?
Anyway, those are some I'm looking at right now.
I'd like to hear opinions, and also suggestions.
Knowing how things go for me I'll probably have to pick some cheap ones up somewhere...
4870 fan: Catalyst auto-fan is too aggressive Bucklaz Video Cards 4 January 7, 2009 12:21 PM
Putting my toe in the water muse108dc Water Cooling 8 November 24, 2008 02:07 PM
help with putting SP3 on a fresh WIN XP? bushwickbill O/S's, Drivers & General Software 2 August 2, 2008 11:26 AM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
Will be putting an 8800GTX, 2 hard drives, and an optical into a Silverstone Sugo! Misoprostol Cases 8 January 28, 2007 05:30 PM
