Old August 6, 2009, 10:01 AM
JD JD is offline
Default Xigmatek Backplates
I'm curious, are the 3-heatpipe models actually different from the 4-heatpipe ones?
It seems like NCIX only ever has the 3-heatpipe ones and for timeliness, I'd rather not have to order from the US to get it.
Or if they are different, is anything that NCIX has in-stock compatible?
Old August 6, 2009, 11:03 AM
Hey Jdrom,
Yes I believe they have different, not sure what exactly is different but the ACK-I7751 is for the 3 heat pipe heatsinks and the ACK-17753 is for the 4 heatpipe heatsinks..
Anitec has the 4 heatpipe one in stock.. Anitec.ca - Xigmatek Crossbow (ACK-I7753)
Maybe it could be that the brackets provided are slightly adjusted or something since the 4 heatpipe covers a little more processor space, hence probably stretches out a little but on both sides..
Old August 6, 2009, 12:18 PM
stoanee's Avatar
You can buy this kit:
NCIX.com - Buy Thermalright LGA775 BOLT-THRU Kit for Ultra 90/120 & HR-01 Retail Box - BTK-LGA775R In Canada.
then remove Intel pushpins from sideplate and install springs and screws.
Name:  22.Push pin close up.JPG
Size:  291.3 KBName:  23.Crossbow clip removal.JPG
Size:  536.9 KBName:  24.Crossbow screw apart.JPG
Size:  447.0 KBName:  25.All done.JPG
heatware
Old August 6, 2009, 02:13 PM
JD JD is offline
Seems easy enough, though I've never had any luck removing push-pins. Ended up just cutting them to pieces
Also came across this one: OCZ OCZTFORC2GM LGA1366 Mounting Conversion Kit for Gladiator Series Heatsinks. Looks like it's the same as XIGMATEK Crossbow I7363 so I assume it would work as well.
Old August 6, 2009, 02:20 PM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
The dif between the 3hdt and 4hdt backplate kits is a sublt difference in the curve of the attachment brakets. Its enough that a 3 kit will not mount on a 4hdt and a 4 kit wil not mount on a 3 hdt. It makes no sense but its the way it is with Xigmatek coolers and their aftermarket backplate kits.
Old August 6, 2009, 03:54 PM
JD JD is offline
Do you know if that OCZ one will work AkG? 99% sure it's the same as Xigmatek's, but I want to make sure.
Old August 6, 2009, 04:12 PM
AkG's Avatar
I know when I wanted a backplate for my OCZ Glad max I used the xigmatek crossbow for the 4hdt xigimateks. So I assume that it would work the other way...but I can not say for sure as I have never used that specific one ;)
Old August 6, 2009, 08:18 PM
JD JD is offline
Alright. Probably end up taking my chances (for my brother anyways )
Xigmatek Thor's Hammer SquattingDawg Air Cooling 3 August 4, 2009 09:24 AM
Lapping my Xigmatek S1283 Inik Case Mods, Worklog & Gallery 17 March 3, 2009 11:20 AM
Xigmatek Thor's Hammer Eagle Eye Air Cooling 10 January 25, 2009 04:42 PM
Xigmatek HDT-S1283 CasheKicker Water Cooling 0 February 19, 2008 01:26 PM
