Old August 5, 2009, 12:44 PM
Default Heatsink Review.. AkG or SKY Please Comment
http://benchmarkreviews.com/index.ph...=292&Itemid=62
I hate to do this, but I have to question 2 coolers that were reviewed by AkG.
In that review, the CM Hyper 212+ doesn't perform as well as it was shown to in the HWC Review, where as the Xigmatek Thor's Hammer didn't perform all that well in the HWC while it seemed to do pretty well in this review.
While the older TRUE performed pretty good too, AkG or SKY please comment as to why these guys were almost totally different results as to the reviews you have done.
Please don't get me wrong, I just wanted to know how or why a good product shows to perform poor in our labs and vice-versa.
Thanks
Old August 5, 2009, 12:56 PM
CMetaphor's Avatar
Quadfather
Hmmmm, all their HSF testing is done vertically, rather than on a flat test bench like in our reviews. I wonder if Not being flat actually helps the coolers with more heatpipes since gravity is not fighting the internal liquid-stuff (brain fart there, forgot what it was called) from returning to the base. It would be interesting to try the exact same cooler flat and on its side (like in a regular tower) to see what the difference truly is.
Old August 5, 2009, 01:04 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Different methodologies, testing conditions, fans, sample differences etc.
And this little golden nugget for the overclocked tests:
To add a final buffing finish, the surface was wet-sanded with ultra-fine 2500 grit and then polished with liquid finishers. When the lapped Core i7-920 was reinstalled into the X58 test platform, the voltage was raised to 1.35V and pushed to a moderate 3.60 GHz overclock
Old August 5, 2009, 01:10 PM
Arinoth's Avatar
So our reviews are without lapping? (just ordered a Cooler Master Hyper 212 a few hours ago, lol)
Here I am: here I remain
sswilson's Avatar
Can't really speak to what testing methodology other sites do, but I'm wondering about the testing procedures on this page....
http://benchmarkreviews.com/index.ph...&limitstart=13
They list their temps as "deg c over ambient". does that mean that they were all tested at the same ambient temps and this is the result, or does it mean that they were test at different ambient temps?
I'm also wondering about the stock fan they list for the Megalems... I thought it didn't ship with a fan.....
Old August 5, 2009, 01:13 PM
SKYMTL's Avatar
No lapped surfaces in our reviews. Lapping can have different effects from one cooler to the next when benchmarking. Some coolers react favourably while others don't. It's as simple as that.
Old August 5, 2009, 01:15 PM
Arinoth's Avatar
Alright, good to hear. I have no clue how to go about it nor do i feel like i want to learn yet, i hope to get similar results are the review (i dont expect identical due to infinite number of variables). Get my i7 up to 3.6-3.8 Ghz stable (with HT) and fold my ass off more!
Old August 5, 2009, 01:16 PM
SKYMTL's Avatar
We use a temperature controlled room which allows us to have accurate temperature readings without using core / ambient deltas. If you can't control the temperature of your room, deltas are no less accurate. HOWEVER, when ambient temps are high they can contribute to the heatsink reaching its thermal limit much faster than if the room was cooler.
Old August 5, 2009, 01:19 PM
stoanee's Avatar
You can only report what you see. I tried a Sunbeam core contact that at the time was highly regarded and it was only a little better than stock. I also tried a Vendetta 2 and despite all the hoopla I found that a Xiggy HDT-S1284 worked better. Eveyone has variables that influence their results in ways that cannot be easily explained so....just gimme the facts!!
heatware
Old August 5, 2009, 01:24 PM
Arinoth's Avatar
Though can you say you are happy with Cooler Master Hyper 212 as it appears in your sig for your i7 rig?
AKG K518DJ anyone use them? Dashock Audio 1 January 27, 2009 09:22 AM
AKG headphones! Cptn Vortex Audio 1 January 11, 2009 06:32 PM
AKG K702 or Senn HD595? Bojamijams Audio 10 December 16, 2008 07:17 PM
Noctua NH-U9B Low Noise Heatsink Review Hardware Canucks Air Cooling 0 April 30, 2008 09:24 AM
Cooljag Falcon 92-Cu Heatsink Review by FrostyTech Babrbarossa Reviews & Articles from the Web 5 May 22, 2007 05:03 PM
