Originally Posted by halfwaythere You don't quite get the point or you're avoiding it. Testing at around 80 oC provides better accuracy. I don't care if someone will ever hit that temperature altho inside a case during summer anything is possible. You as a tester should be interested in getting the most accurate results even if in real life a very few user will be pushing their setup that high. |
I do get the point, and in fact make mention of suitability for lower temp platforms vrs higher temp ones in the 212+ AM3 results I posted. (I am no longer an active reviewer BTW, so those are posted as a member using his own off-the shelf kit rather than as HWC staff).
Where the disconnect between our views on the subject is your use of the word "accurate" in an attempt to discredit results gathered outside of the extreme environment you would like to see all tests carried out under.
We can agree to disagree, but as a consumer of reviews, I stand by my view of preferring reviews based on what I personally could be expected to see on my own gear, rather than what I'd see under extreme conditions, especially if the results from extreme testing conditions will greatly skew expectations of performance.
I look at overclocking results under Phase/LN2 the same way. I could care less if one particular platform would allow me an 80% overclock under extreme cooling while another would only offer 40%. If the two platforms offer about the same headroom under the cooling options I'd use, that's what I personally want to know, and the LN2 results while interesting, aren't much use to me.
On a final note.... while we do encourage folks to question the way we do things around here, and do everything in our power to not stiffle legitimate debate, suggesting that any member (or staff) is actively "avoiding" accepting your POV rather than debating it suggests that you're accusing folks of trying to be deceitful. That's not the kind of debate we expect to see around here.
